Here is a sketch to test - now draws to the LCD in 2.0-sec, I had a silly delay in there before.
file: arducam_lcd1_0.ino
revised: 02/07/16 (orig 02/06/16)
author: oric_dan
cpus: UNO(tested ok)
Program to test Arducam-Mini capture directly to LCD display.
Uses Arducam-Mini BMP mode, QVGA 320x240 (this is the only
non-JPEG mode built into the Arducam library).
Special Notes:
1. best to run Adafruit graphicstest.ino example first to
verify LCD shield working properly.
Bug Notes:
1. in modified sketch, when writing direct to LCD in
capture2Lcd(), the first (dummy) FIFO read needs
to be removed or colors are hosed, also s/b
"unsigned char VH,VL;" rather than "char VH,VL;".
2. DISP_ROTATE value may need to be changed when 1.8" LCD
"module" is used.
Notes:
1. ArduCam-Mini I/O pins are specified as 5V tolerant.
2. sketch adapted from "progress_camera_screen_crop.ino" here:
http://forum.arduino.cc/index.php?topic=376790.0
3. sketch changes: removed SD store, and modified for direct
image display on 160x128 ST7735 LCD.
4. capture and draw takes about 2.0-sec using pushColor()
method, and 3.8-sec using drawPixel() method.
Screen Orientation
- for rotation(r=0), coordinates shown as (x,y):
+(0,159)-------------(0,0)+
| | | width height
| Hline --Vline-- | |
| | | w -h-
+(127,159)---------(127,0)+ |
- origin (x,y)=(0,0) shown for screen rotations (r=0,1,2,3):
+(r=3)-----(r=0)+
+(r=2)-----(r=1)+
Original links:
// http://forum.arduino.cc/index.php?topic=285778.0
// inspired by
http://sauerwine.blogspot.fr/2013/07/an-arduino-time-lapse-camera-using.html
http://www.arducam.com/how-arducam-use-a-external-trigger-from-a-sensor/
#include <Adafruit_GFX.h> //Core graphics library
#include <Adafruit_ST7735.h> //Hardware-specific library
#include <SPI.h>
#include <Wire.h>
//#include <SD.h> //SD support removed.
#include <ArduCAM.h>
#include <memorysaver.h>
#include <avr/pgmspace.h>
char *progname="\nArducam-Mini Capture-to-Lcd1_0...(02/07/16)";
#define dbg Serial
//// select setup for LCD module or shield ////
#if false
// camera setup - from original sketch/
// uses Adafruit 1.8" LCD "module", p/n 358.
#define SD_CS 9 //SD card chip-select
#define TFT_CS 10 //Chip select line for TFT display
#define TFT_RST 3 //Reset line for TFT (or see below...)
#define TFT_DC 8 //Data/command line for TFT
const int screenlite=A2;
#define DISP_ROTATE 3 // MAY NEED TO BE CHANGED.
const int CAM_CS=7; //Arducam CS pin.
#else
// setup for Adafruit 1.8" TFT "shield".
//#define SD_CS 4 //SD card chip-select
#define TFT_RST 0 //Reset line for TFT
#define DISP_ROTATE 3 //draws right side up.
//#define DISP_ROTATE 1 //draws up side down.
#endif
// instantiate LCD and ArduCAM.
Adafruit_ST7735 tft=Adafruit_ST7735(TFT_CS,TFT_DC,TFT_RST);
ArduCAM myCAM1(OV2640,CAM_CS);
// control macros - go inline //
#define cam_assert() digitalWrite(CAM_CS,LOW)
#define cam_desert() digitalWrite(CAM_CS,HIGH)
#define lcd_assert() digitalWrite(TFT_CS,LOW)
#define lcd_desert() digitalWrite(TFT_CS,HIGH)
uint8_t vid, pid, temp;
dbg.begin(115200);
dbg.println(progname);
disp_freeram();
//pinMode(screenlite, OUTPUT);
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
pinMode(CAM_CS,OUTPUT);
digitalWrite(CAM_CS,HIGH);
SPI.begin();
Wire.begin();
// initializer for 1.8" TFT.
tft.initR(INITR_BLACKTAB);
rotate_test(500); //write test lines.
delay(2000);
tft.setRotation(DISP_ROTATE); //set rotation for images.
tft.fillScreen(ST7735_BLACK);
// check if the ArduCAM SPI bus is ok.
myCAM1.write_reg(ARDUCHIP_TEST1, 0x55);
temp=myCAM1.read_reg(ARDUCHIP_TEST1);
dbg.print("Camera SPI comms..");
if(temp != 0x55) {
dbg.println("Error, halt!"); while(1);
else dbg.println("OK");
// check if the Arducam module type is OV2640.
myCAM1.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM1.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
dbg.print("Camera I2C comms..");
if( (vid != 0x26) || (pid != 0x42) ) {
// change MCU mode (?)
myCAM1.write_reg(ARDUCHIP_MODE,0x00);
myCAM1.InitCAM();
if( dbg.available() ) { //hold picture on keypress.
while(1);
startCapture();
capture2Lcd();
// this is the slower method.
// startCapture();
// capture2Lcd2();
//delay(5000);
/* captures QVGA 320x240 image from camera, and writes
* directly to 160x128 LCD using 4:1 decimation.
* - uses pushColor().
void capture2Lcd( void )
unsigned char VH,VL; //must be unsigned.
uint8_t temp;
int row, col;
int xo=0, yo=0; //start position of displayed image.
uint16_t color;
unsigned long prevtm;
dbg.print("Writing picture 1...");
prevtm=millis();
// set TFT address window bounds to entire screen.
int w=160, h=120; //width,height of displayed image.
tft.setAddrWindow(xo, yo, xo+w-1, yo+h-1);
// read dummy byte from FIFO.
//temp=myCAM1.read_fifo(); //remove,screws up LCD color scheme.
// read 320x240x2 byte from FIFO, but draw only every
// other row, and every other pixel on each row drawn.
for( row=0; row<240; row++) {
// process every other col pixel.
for( col=0; col<(320/2); col++) {
cam_assert();
VH=myCAM1.read_fifo(); //get every other col pixel.
VL=myCAM1.read_fifo();
temp=myCAM1.read_fifo(); //toss next pixel.
cam_desert();
if( (row%2) == 0) { //draw only every other row.
lcd_assert();
color = (VH << 8 ) | VL; //compute RGB565 color.
tft.pushColor(color);
lcd_desert();
dbg.println("finished");
dbg.print( millis()-prevtm );
dbg.println(" msec");
* - uses drawPixel().
void capture2Lcd2()
uint8_t temp;
int row, col;
int w=160, h=128; //width, height " " " .
uint16_t color;
dbg.print("Writing picture 2...");
prevtm=millis();
// other row, and every other pixel on each row.
cam_assert();
VH=myCAM1.read_fifo(); //get pixel.
cam_desert();
lcd_assert();
tft.drawPixel( col, (row/2), color);
lcd_desert();
/* simple to use function, which takes a picture either in
* JPEG or BMP format in function of the 'mode' constant.
void startCapture( void )
dbg.print("Taking picture...");
myCAM1.write_reg(ARDUCHIP_MODE, 0x00);
myCAM1.set_format(BMP);
myCAM1.InitCAM();
myCAM1.flush_fifo(); //clear ArduCAM buffer.
myCAM1.clear_fifo_flag(); //start capture.
myCAM1.start_capture();
while( !(myCAM1.read_reg(ARDUCHIP_TRIG) & CAP_DONE_MASK) ) {
delay(10);
myCAM1.InitCAM();
[/code
