Arducam photos to computer
I have an Arduino Uno board and Arducam shield with OV2640 camera module. I have managed to setup the system ok and take photos and get them stored to a SD card. I, however, have had no luck in finding a tutorial how to get the photos transmitted to my computer via USB cable. Where should I look for the help with this topic?
Regards,
Sauli.
You have two choices. You can pull out the SD card and stick it in a slot in your computer.
Or you can write a program to copy the file to the computer. You will need two programs. You will need one program on the arduino to send the file, and another program on the computer to receive the file and store it onto the hard disk of the computer.
I am sure someone has already done this, but in what context, I don't know.
Thanks for the help.
In the Arducam library there seems to be an example about sending the file to computer: “ArduCAM_SPI_xxxx_FIFO_UART -This example demonstrates how to transfer the image back to host computer via Arduino board USB port or serial port. It is useful when user wants to transfer the image wirelessly by bluetooth, Zigbee, Xbee or GPRS/3G.”
The code of the example is below. I have not been able to figure out is the file automatically saved somewhere on my computer or should I do something to capture it.
// ArduCAM demo (C)2013 Lee
// web: http://www.ArduCAM.com
// This program is a demo of how to use most of the functions
// of the library with a supported camera modules.
// This demo was made for Omnivision OV2640 sensor.
// 1. Set the sensor to JPEG output mode.
// 2. Capture and buffer the image to FIFO.
// 3. Transfer the captured JPEG image back to host via Arduino board USB port.
// 4. Resolution can be changed by myCAM.OV2640_set_JPEG_size() function.
// This program requires the ArduCAM V3.0.0 (or above) library and Rev.C ArduCAM shield
// and use Arduino IDE 1.5.2 compiler
#include <UTFT_SPI.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
// set pin 10 as the slave select for the digital pot:
const int slaveSelectPin = 10;
ArduCAM myCAM(OV2640,10);
UTFT myGLCD(slaveSelectPin);
  #if defined (__AVR__)
    Wire.begin();
  #endif
  #if defined(__arm__)
    Wire1.begin();
  #endif
  Serial.println("hello");
  // set the slaveSelectPin as an output:
  pinMode(slaveSelectPin, OUTPUT);
  // initialize SPI:
  SPI.begin();
  myCAM.write_reg(ARDUCHIP_MODE, 0x00);
  //myGLCD.InitLCD();
  myCAM.OV2640_set_format(JPEG);
  myCAM.InitCAM();
  myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);
  uint8_t temp,temp_last;
  uint8_t start_capture = 0;
  temp = Serial.read();
  switch(temp)
    case 0:
      myCAM.OV2640_set_JPEG_size(OV2640_160x120);
    case 1:
      myCAM.OV2640_set_JPEG_size(OV2640_176x144);
    case 2:
      myCAM.OV2640_set_JPEG_size(OV2640_320x240);
    case 3:
      myCAM.OV2640_set_JPEG_size(OV2640_352x288);
    case 4:
      myCAM.OV2640_set_JPEG_size(OV2640_640x480);
    case 5:
      myCAM.OV2640_set_JPEG_size(OV2640_800x600);
    case 6:
      myCAM.OV2640_set_JPEG_size(OV2640_1024x768);
    case 7:
      myCAM.OV2640_set_JPEG_size(OV2640_1280x1024);
    case 8:
    case 0x10:
      start_capture = 1;
      Serial.println("start");
      myCAM.flush_fifo();
    default:
  //start_capture = 1;
  if(start_capture)
    //Clear the capture done flag
    myCAM.clear_fifo_flag();
    //Start capture
    myCAM.start_capture();
  if(myCAM.read_reg(ARDUCHIP_TRIG) & CAP_DONE_MASK)
    //Serial.write(0xff);
    //temp = myCAM.read_fifo();
    //Serial.write(temp);
    while( (temp != 0xD9) | (temp_last != 0xFF) )
        temp_last = temp;
	Serial.write(temp);
    start_capture = 0;
Sauli_:
It looks like the code is just dumping the bytes of the JPEG image down the serial port; you would need to create a program for the PC side of things to read the serial port, and write that byte stream to a file (or store it in memory - whatever you intend to do with it).
Do you have a program or code for a program that can read the byte stream and display a JPEG?
