Arduino 0007 on Mandriva 2007 - errors
I tried to run Arduino 0007 on Mandriva 2007. I installed it in user space and it runs, but it reports all sorts of errors. The status bar says: Error building library “Wire”, and below there are several error messages:
utility/twi.c:20:18: error: math.h: No such file or directory
utility/twi.c:21:20: error: stdlib.h: No such file or directory
utility/twi.c:22:22: error: inttypes.h: No such file or directory
utility/twi.c:23:20: error: avr/io.h: No such file or directory
utility/twi.c:24:27: error: avr/interrupt.h: No such file or directory
utility/twi.c:25:24: error: avr/signal.h: No such file or directory
utility/twi.c:26:24: error: compat/twi.h: No such file or directory
In file included from utility/twi.c:36:
utility/twi.h:46: warning: parameter names (without types) in function declaration
utility/twi.h:47: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_readFrom’
utility/twi.h:48: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_writeTo’
utility/twi.h:49: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_transmit’
utility/twi.h:50: error: expected declaration specifiers or ‘…’ before ‘uint8_t’
utility/twi.h:52: warning: parameter names (without types) in function declaration
utility/twi.c:38: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_state’
utility/twi.c:39: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_slarw’
utility/twi.c:42: error: expected ‘)’ before ‘’ token
utility/twi.c:44: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before '
’ token
utility/twi.c:45: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_masterBufferIndex’
utility/twi.c:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_masterBufferLength’
utility/twi.c:48: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘’ token
utility/twi.c:49: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_txBufferIndex’
utility/twi.c:50: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_txBufferLength’
utility/twi.c:52: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before '
’ token
utility/twi.c:53: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_rxBufferIndex’
utility/twi.c: In function ‘twi_init’:
utility/twi.c:64: error: ‘twi_state’ undeclared (first use in this function)
utility/twi.c:64: error: (Each undeclared identifier is reported only once
utility/twi.c:64: error: for each function it appears in.)
utility/twi.c:74: warning: implicit declaration of function ‘_SFR_BYTE’
utility/twi.c:74: error: ‘PORTD’ undeclared (first use in this function)
utility/twi.c:74: warning: implicit declaration of function ‘_BV’
utility/twi.c:74: error: invalid lvalue in assignment
utility/twi.c:75: error: invalid lvalue in assignment
utility/twi.c:79: error: ‘TWSR’ undeclared (first use in this function)
utility/twi.c:79: error: ‘TWPS0’ undeclared (first use in this function)
utility/twi.c:79: error: invalid lvalue in assignment
utility/twi.c:80: error: ‘TWPS1’ undeclared (first use in this function)
utility/twi.c:80: error: invalid lvalue in assignment
utility/twi.c:81: error: ‘TWBR’ undeclared (first use in this function)
utility/twi.c:89: error: ‘TWCR’ undeclared (first use in this function)
utility/twi.c:89: error: ‘TWEN’ undeclared (first use in this function)
utility/twi.c:89: error: ‘TWIE’ undeclared (first use in this function)
utility/twi.c:89: error: ‘TWEA’ undeclared (first use in this function)
utility/twi.c:92: error: ‘twi_masterBuffer’ undeclared (first use in this function)
utility/twi.c:92: error: ‘uint8_t’ undeclared (first use in this function)
utility/twi.c:92: error: expected expression before ‘)’ token
utility/twi.c:93: error: ‘twi_txBuffer’ undeclared (first use in this function)
utility/twi.c:93: error: expected expression before ‘)’ token
utility/twi.c:94: error: ‘twi_rxBuffer’ undeclared (first use in this function)
utility/twi.c:94: error: expected expression before ‘)’ token
utility/twi.c: At top level:
utility/twi.c:103: error: expected ‘)’ before ‘address’
utility/twi.c:118: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_readFrom’
utility/twi.c:167: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_writeTo’
utility/twi.c:216: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘twi_transmit’
utility/twi.c:245: error: expected ‘)’ before ‘*’ token
utility/twi.c: In function ‘twi_attachSlaveRxEvent’:
utility/twi.c:246: error: number of arguments doesn’t match prototype
utility/twi.h:50: error: prototype declaration
utility/twi.c:247: error: ‘twi_onSlaveReceive’ undeclared (first use in this function)
utility/twi.c:247: error: ‘function’ undeclared (first use in this function)
utility/twi.c:267: error: expected ‘)’ before ‘ack’
utility/twi.c: In function ‘twi_stop’:
utility/twi.c:286: error: ‘TWCR’ undeclared (first use in this function)
utility/twi.c:286: error: ‘TWEN’ undeclared (first use in this function)
utility/twi.c:286: error: ‘TWIE’ undeclared (first use in this function)
… etc.
If I install arduino as root, it doesn’t even run, saying:
Exception in thread “main” java.lang.NoClassDefFoundError: processing/app/Base
Any ideas?
It looks like your C/C++ compiler (avr-gcc/avr-g++) can’t find your avr-libc. Did you install avr-libc? Where is it?
Aah, you're right, I forgot to compile avr-libc. ::) Thanks for your help, now it works. :)
