When using any external interrupts with the arduino 0016 software for the pro mini 8mhz you get an error when you compile.
Hmm, I didn't have any problems with the sample program I just tried. Can you post your code and the error you get? Which boards give you the error and which don't?
mellis,
Thanks for the quick reply. The code I am having trouble with is a three tab file. This code does fully compile with zero errors in the Arduino-0015 environment for an Arduino Pro or Pro Mini (3.3V, *MHz) w/ ATMega168. Hopefully this will help.
Tab 1 Code:
//Variable Initialization, Setup, and Main loop
//Magnetometer and Period Variables
volatile int time=0;
volatile int period=0;
volatile int new_period=0;
volatile int last_period=0;
volatile byte count=0;
volatile int first_half=0;
volatile int second_half=0;//Timer 2 ISR variables
int mode=1;
int isr_count=0;void setup()
pinMode(3,INPUT); //mag data
pinMode(4,OUTPUT); //mag reset
pinMode(8,OUTPUT); //flap
pinMode(9,OUTPUT); //throttle
pinMode(13,OUTPUT); //leddegauss();
degauss();Serial.begin(19200);
TCCR2A=0x02;
TCCR2B=0x07;
TCNT2=0x00;
OCR2A=0x9C;
GTCCR=0x02;
TIMSK2=0x02;attachInterrupt(1,getRPM,RISING);
if (count==30)
count=0;
Serial.println(period);
degauss();
Tab 2 Code:
//replaces get_RPM function
/boolean blink=false;
void getRPM()
if (millis()>80)
blink=!blink;
if (blink) PORTB |= 1<<PB5;
else PORTB &= ~(1<<PB5);
}///set mode of timer2 isr in order to sync up flapping
void getRPM()
time=millis();
if (time>80)
mode=4;
count++;
new_period=time;
last_period=period;
period=((period<<2)-period+new_period)>>2;
first_half=period>>1;
second_half=period-first_half;
timer_reset();
}void degauss()
//assumes that the magreset pin is connected to 4
PORTD|=1<<PD4;
delayMicroseconds(2);
PORTD&=~(1<<PD4);
}extern volatile unsigned long timer0_clock_cycles;
extern volatile unsigned long timer0_millis;
void timer_reset()
unsigned char oldSREG=SREG;
cli();
timer0_clock_cycles=0;
timer0_millis=0;
SREG=oldSREG;
}//original getrpm
/void getRPM()
time=millis();
if (time>80)
if (time>300) time=300;
count++;
new_period=time;
last_period=period;
timer_reset();
Tab 3 Code:
//ISR routine for translation
ISR(TIMER2_COMPA_vect)
switch(mode)
{case 1: //wait for half period
isr_count++;
if (isr_count==first_half)
mode=2;
TCCR2B=0x04;
OCR2A=125;
GTCCR=0x02;
case 2: //turn led off
PORTB &= ~(1<<PB5);
TCCR2B=0x04;
OCR2A=125;
GTCCR=0x02;
mode=3;
isr_count=0;
case 3: //
isr_count++;
if (isr_count==second_half)
mode=4;
TCCR2B=0x04;
OCR2A=125;
GTCCR=0x02;
case 4: //turn led on
PORTB |= 1<<PB5;
TCCR2B=0x04;
OCR2A=125;
GTCCR=0x02;
mode=1;
isr_count=0;
default:
That is the end of the code and this is the list of errors that I am getting.
o: In function timer_reset': C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build39811.tmp/Temporary_1953_2035.cpp:111: undefined reference to
timer0_clock_cycles’
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build39811.tmp/Temporary_1953_2035.cpp:111: undefined reference to `timer0_clock_cycles’
Couldn’t determine program size: C:\Documents and Settings\Administrator\Desktop\IARC\software and drivers\arduino-0016\arduino-0016\hardware/tools/avr/bin/avr-size: ‘C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\build39811.tmp\Translation_Debugging.hex’: No such file
timer0_clock_cycles is (was) an internal / unsupported variable. You'll have to take a look inside the wiring.c to find a equivalent technique for Arduino 0016.
