Arduino 0017 on Fedora 10 - no avr-g++ on compile?
Folks,
Any idea why Fedora 10 is missing avr-g++? The message I see is 'Cannot run program "avr-g++":j ava.io.IOException:Error=2: No such file or directory' - when I compile a sketch.
I'm compiling using 0017 running on a Linux box with a vanilla Fedora Core 10 install, the Sun Java 1.6.0 runtime (downloaded from Sun, not the linux Blackdown build), and the avr packages recommended on the Fedora install pages here at arduino.cc/playground/Linux/Fedora - which I followed to get the environment set up correctly.
I did a find / -name avr-g++ -print to see if this executable was on the machine but in the wrong folder, and it isn't found anywhere on the box.
To remind you, the ones noted for Fedora 11 in the installation tutorial are:
  • uisp-20050207-5.fc11.i386
  • avr-libc-1.6.4-1.fc11
  • avr-gcc-c++-4.3.3-2.fc11
  • avr-gcc-4.3.3-2.fc11
  • avr-binutils-2.18-4.fc11
Since I'm running on Fedora 10 I have a couple of small differences (output from "yum info" follows:-)
Available Packages
Arch : i386
Version : 20050207
Release : 4.fc10
Repo : fedora
Summary : Universal In-System Programmer for Atmel AVR and 8051
Arch : noarch
Version : 1.6.4
Release : 1.fc10
Repo : installed
From repo : updates
Summary : C library for use with GCC on Atmel AVR microcontrollers
Arch : i386
Version : 4.3.3
Release : 1.fc10
Repo : updates
Summary : Cross Compiling GNU GCC targeted at avr
Arch : i386
Version : 4.3.3
Release : 1.fc10
Repo : installed
From repo : updates
Arch : i386
Version : 2.18
Release : 2.fc9
Repo : installed
From repo : fedora
Summary : Cross Compiling GNU binutils targeted at avr
Can anyone suggest which package should provide avr-g++ in the Fedora 10 repositories, or if none do, what I'd need to do to compile from src? Google shows a couple of other old posts elsewhere on this, but those are for previous versions of the software. :-/
Thanks!
Jerry
I don't use Fedora anymore (moved to Ubuntu) but you could try:
rpm -q --whatprovides avr-g++
This should tell you what package contains avr-g++.
HTH
Ver
Thanks for the suggestion Ver
no package provides avr-g++
I found this on http://www.rpmfind.net
http://fr2.rpmfind.net//linux/RPM/fedora/updates/10/i386/avr-gcc-c++-4.3.3-1.fc10.i386.html
If you scroll down to the bottom of that page it says it provides avr-g++, If you need the x86-64 version they have that too.
HTH
fixed the url
Ver
Fixed! :smiley:
Thanks Ver!
I've added the solution to Arduino Playground - HomePage
Best regards,
Jerry
In the package info from your first post:
Arch : i386
Version : 4.3.3
Release : 1.fc10
Repo : updates
we can see that avr-gcc-c++ was available (from Repo updates) but not installed on your computer. All the other packages are listed as Repo: installed.
So the simple solution should be to just run "yum install avr-gcc-c++"
Jerry's problem was that he knew he needed a file called avr-g++. However, he didn't know which of the packages he listed actually contained that file.
Ver
