arduino 0017 will not run mstimer2
Hello,
I have been using Arduino 0016 & the MsTimer2 library without any problem for the duemilanove w atmega328. so far so good.
after upgrading to 0017 i receive compiler errors, which indicate that the atmega328p is not defined, as a result the mcu is undefined & the library will not work.
any idea how to resolve this ?
s
What operating system are you on? Do you have the same problem if you remove the MsTimer2 library (or compile a sketch that doesn't use it)?
sorry for the delay
working on ubuntu linux 8.04
adnd yes indeed, it is not only mstimer2 but also the regular compile, where the atmega328p is not defined.
had no problems with mac os x 10.4.11 and arduino 0017
s
the atmega328 on your ubuntu-version uses an older avr-gcc compiler-version which does not support the chip.
There are two ways to resolve this:
Upgrade to a more recent version of Ubuntu (8.10 at least).
(This should be easier than the second option...)
Check out the hints given towards the end of this thread
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1238853601
the link to some external tutorials on this
Eberhard
thx,
will look into this - but then, why did I not have any problems using arduino 0016 on the same linux machine ?
s
Wasn't clear to me from what I've read.
You can compile for the atmega328 when using arduino-0016, but it fails when using arduino-0017?
Could you post a small example sketch and the error messages?
Eberhard
hi,
was busy the last weeks.
so I checked and indeed the same error messages occur if I compile any other program. for simplicity I took 'blink' from the sample libraries.
error messages abound:
unknown MCU 'atmega328p' specified
Known MCU names:
   avr2
   at90s2313
   at90s2323
   at90s2333
   at90s2343
   attiny22
   attiny26
   at90s4414
   at90s4433
   at90s4434
   at90s8515
   at90c8534
   at90s8535
   avr25
   attiny13
   attiny2313
   attiny24
   attiny44
   attiny84
   attiny25
   attiny45
   attiny85
   attiny261
   attiny461
   attiny861
   at86rf401
   avr3
   atmega103
   atmega603
   at43usb320
   at43usb355
   at76c711
   avr4
   atmega8
   atmega48
   atmega88
   atmega8515
   atmega8535
   atmega8hva
   at90pwm1
   at90pwm2
   at90pwm3
   avr5
   atmega16
   atmega161
   atmega162
   atmega163
   atmega164p
   atmega165
   atmega165p
   atmega168
   atmega169
   atmega169p
   atmega32
   atmega323
   atmega324p
   atmega325
   atmega325p
   atmega3250
   atmega3250p
   atmega329
   atmega329p
   atmega3290
   atmega3290p
   atmega406
   atmega64
   atmega640
   atmega644
   atmega644p
   atmega645
   atmega6450
   atmega649
   atmega6490
   atmega128
   atmega1280
   atmega1281
   atmega16hva
   at90can32
   at90can64
   at90can128
   at90usb82
   at90usb162
   at90usb646
   at90usb647
   at90usb1286
   at90usb1287
   at94k
   avr1
   at90s1200
   attiny11
   attiny12
   attiny15
   attiny28
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:1: error: MCU [ch8216]atmega328p[ch8217] supported for assembler only
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c: In function [ch8216]micros[ch8217]:
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:82: error: [ch8216]TCNT0[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:82: error: (Each undeclared identifier is reported only once
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:82: error: for each function it appears in.)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:88: error: [ch8216]TIFR[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:88: error: [ch8216]TOV0[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c: In function [ch8216]init[ch8217]:
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:178: error: [ch8216]TCCR0A[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:178: error: [ch8216]WGM01[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:179: error: [ch8216]WGM00[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:186: error: [ch8216]TCCR0B[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:186: error: [ch8216]CS01[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:187: error: [ch8216]CS00[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:193: error: [ch8216]TIMSK0[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:193: error: [ch8216]TOIE0[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:202: error: [ch8216]TCCR1B[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:202: error: [ch8216]CS11[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:203: error: [ch8216]CS10[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:205: error: [ch8216]TCCR1A[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:205: error: [ch8216]WGM10[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:211: error: [ch8216]TCCR2B[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:211: error: [ch8216]CS22[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:217: error: [ch8216]TCCR2A[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:217: error: [ch8216]WGM20[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:235: error: [ch8216]ADCSRA[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:235: error: [ch8216]ADPS2[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:236: error: [ch8216]ADPS1[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:237: error: [ch8216]ADPS0[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:240: error: [ch8216]ADEN[ch8217] undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:248: error: [ch8216]UCSR0B[ch8217] undeclared (first use in this function)
I have de-installed and installed the gcc-avr libs and it still does not work in my linux. any ideas ?
s
This has cropped up quite a lot.
The info here Pololu - Developing for the ATmega328P under Linux may help.
Hi again,
so instead of compiling my gcc, i upgraded to 9.04.
now, the same blink creates the following error messages:
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring_private.h:28:20: error: avr/io.h: No such file or directory
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring_private.h:29:27: error: avr/interrupt.h: No such file or directory
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring_private.h:30:23: error: avr/delay.h: No such file or directory
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring_private.h:31:19: error: stdio.h: No such file or directory
                 from /home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:25:
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:101: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'boolean'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:102: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'byte'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:110: error: expected ')' before 'mode'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:111: error: expected ')' before 'int'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:123: error: expected ')' before 'pin'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:125: error: expected ')' before 'dataPin'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.h:127: error: expected ')' before 'void'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c: In function 'millis':
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:66: error: 'uint8_t' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:66: error: (Each undeclared identifier is reported only once
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:66: error: for each function it appears in.)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:66: error: expected ';' before 'oldSREG'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:72: error: 'SREG' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:72: error: 'oldSREG' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c: In function 'micros':
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:79: error: 'uint8_t' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:79: error: expected ';' before 'oldSREG'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:82: error: 'TCNT0' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:88: error: 'TIFR' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:88: error: 'TOV0' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:93: error: 'SREG' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:93: error: 'oldSREG' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c: In function 'delayMicroseconds':
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:111: error: 'uint8_t' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:111: error: expected ';' before 'oldSREG'
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:155: error: 'oldSREG' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:155: error: 'SREG' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c: In function 'init':
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:178: error: 'TCCR0A' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:178: error: 'WGM01' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:178: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:179: error: 'WGM00' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:179: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:186: error: 'TCCR0B' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:186: error: 'CS01' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:186: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:187: error: 'CS00' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:187: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:193: error: 'TIMSK0' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:193: error: 'TOIE0' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:193: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:202: error: 'TCCR1B' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:202: error: 'CS11' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:202: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:203: error: 'CS10' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:203: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:205: error: 'TCCR1A' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:205: error: 'WGM10' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:205: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:211: error: 'TCCR2B' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:211: error: 'CS22' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:211: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:217: error: 'TCCR2A' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:217: error: 'WGM20' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:217: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:235: error: 'ADCSRA' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:235: error: 'ADPS2' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:235: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:236: error: 'ADPS1' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:236: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:237: error: 'ADPS0' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:237: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:240: error: 'ADEN' undeclared (first use in this function)
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:240: error: lvalue required as left operand of assignment
/home/reinhard/Desktop/arduino-0017/hardware/cores/arduino/wiring.c:248: error: 'UCSR0B' undeclared (first use in this function)
so is now the problem in wiring ?
thanks for your help
s
looks like package avr-libc is not installed (or wasn't upgraded?)
Install the package "avr-libc" with adept or apt-get because the install process creates some links to the library so the compiler can find them.
Eberhard
