Your code does not compile. You are missing some declarations, as well as have re-declarations.
Would you verify this: It looks like you want your code to light the LEDs one at a time, moving in one direction... with the question, "How do you change the direction with a "shake" (button press)?"
I added a pushbutton to your code. Here are the files to use on WOKWI.COM...
"sketch.ino" tab:
unsigned long PreviousTime = 0; //Using the unsigned long variable as expleined before
int InterruptorState = 0; //Initialtating variables
int PreviousStateInterruptor = 0;
int Led = 2; //Variable used to count which LED will be the next on lighting
long TimeIntervalocadaLed = 1000; //Every 1 second(s) a LED will light
int c = 0;
int PinInterruptor = 9;
for (int x = 2; x < 8; x++) {
pinMode(x, OUTPUT); //Stablishing all the LEDs as outputs
// pinMode(PinInterruptor, INPUT); //Stablishing the switch as an input
pinMode(PinInterruptor, INPUT_PULLUP); // better button
unsigned long ActualTime = millis(); //Knowing how long the program has been working
if (ActualTime - PreviousTime > TimeIntervalocadaLed) { //Veryfing if has transcurred the required time to switch on another LED
PreviousTime = ActualTime;
digitalWrite(Led, HIGH); //Lighting a new LED
Led++;//Preparing to light the next one
if (Led == 7) { //In case that there is just one LED switch off advise by blinking all LEDs when the time is about to finish(2.5 seconds before)
// delay(2500);
c = 0;
while (c < 5) {
digitalWrite(x, LOW);
// delay(500);
digitalWrite(x, HIGH);
// delay(500);
c++;
InterruptorState = digitalRead(PinInterruptor); //Read sensor state
delay(150);
if (InterruptorState != PreviousStateInterruptor) { //Puting all variables at zero if the state has changed
Led = 2;
PreviousStateInterruptor = InterruptorState; //Stablishing the actual state as the previous one
"diagram.json" tab:
"version": 1,
"author": "Anonymous maker",
"editor": "wokwi",
"parts": [
{ "type": "wokwi-arduino-nano", "id": "nano", "top": 33.6, "left": 47.5, "attrs": {} },
"type": "wokwi-led",
"id": "led1",
"top": -80.4,
"left": 71,
"attrs": { "color": "red", "flip": "" }
"id": "led2",
"top": -80.4,
"left": 51.8,
"id": "led5",
"top": -80.4,
"left": 147.8,
"id": "led6",
"top": -80.4,
"left": 128.6,
"id": "led7",
"top": -80.4,
"left": 109.4,
"id": "led8",
"top": -80.4,
"left": 90.2,
"type": "wokwi-resistor",
"id": "r3",
"top": -4.8,
"left": 85.85,
"rotate": 90,
"attrs": { "value": "1000" }
"id": "r4",
"top": -4.8,
"left": 95.45,
"rotate": 90,
"id": "r5",
"top": -4.8,
"left": 105.05,
"rotate": 90,
"id": "r6",
"top": -4.8,
"left": 114.65,
"rotate": 90,
"id": "r7",
"top": -4.8,
"left": 124.25,
"rotate": 90,
"id": "r8",
"top": -4.8,
"left": 133.85,
"rotate": 90,
"type": "wokwi-pushbutton",
"id": "btn1",
"top": -22.6,
"left": 28.8,
"attrs": { "color": "green" }
"connections": [
[ "led5:A", "r8:1", "green", [ "v9.6", "h76.8" ] ],
[ "r7:1", "led6:A", "green", [ "h-76.8" ] ],
[ "r6:1", "led7:A", "green", [ "h0" ] ],
[ "r5:1", "led8:A", "green", [ "h-105.6" ] ],
[ "r4:1", "led1:A", "green", [ "h0" ] ],
[ "r3:1", "led2:A", "green", [ "h0" ] ],
[ "r8:2", "nano:2", "green", [ "h0" ] ],
[ "r7:2", "nano:3", "green", [ "h0" ] ],
[ "nano:4", "r6:2", "green", [ "v0" ] ],
[ "nano:5", "r5:2", "green", [ "v0" ] ],
[ "r4:2", "nano:6", "green", [ "h0" ] ],
[ "nano:7", "r3:2", "green", [ "v0" ] ],
[ "nano:GND.2", "led5:C", "black", [ "v-9.6", "h-96.4" ] ],
[ "led5:C", "led6:C", "green", [ "v0" ] ],
[ "led6:C", "led7:C", "green", [ "v0" ] ],
[ "led7:C", "led8:C", "green", [ "v0" ] ],
[ "led8:C", "led1:C", "green", [ "v0" ] ],
[ "led1:C", "led2:C", "green", [ "v0" ] ],
[ "nano:GND.2", "btn1:1.r", "black", [ "v-9.6", "h-67.2", "v-38.4" ] ],
[ "btn1:2.r", "nano:9", "green", [ "h0" ] ]
"dependencies": {}
