ARDUINO 1.0.5 - error: WConstants.h: No such file or directory
Hi
i verify program .Now with hardware the Arduino UNO and Arduino 1.0.5 I get the error:
C:\Program Files\Arduino\libraries\sdc328\FAT16.cpp:27:24: error: WConstants.h: No such file or directory
that you see in code.
Can you please advise what changes I should do - probably with the libraries..many thanks
// LinkSprite.com
// Note:
// 1. SD must be formated to FAT16
// 2. As the buffer of softserial has 64 bytes, so the code read 32 bytes each time
// 3. Please add the libaray to the lib path
#include <SoftwareSerial.h>
#include <byteordering.h>
#include <fat.h>
#include <FAT16.h>
#include <fat_config.h>
#include <partition.h>
#include <partition_config.h>
#include <sd-reader_config.h>
#include <sd_raw.h>
#include <sd_raw_config.h>
byte incomingbyte;
SoftwareSerial mySerial(4, 5);        // Set Arduino pin 4 and 5 as softserial
long int a=0x0000,j=0,k=0,count=0,i=0;
uint8_t MH,ML;
boolean EndFlag=0;
FAT TestFile;
void SendResetCmd();
void SetBaudRateCmd();
void SetImageSizeCmd();
void SendTakePhotoCmd();
void SendReadDataCmd();
void StopTakePhotoCmd();
  Serial.begin(38400);
  mySerial.begin(38400);
  pinMode(2,OUTPUT);       //pin 2 is connected to LED to indicate the status of SD card initialization
  if(!sd_raw_init())
    digitalWrite(2,HIGH);
    while(1);
 TestFile.initialize();
 TestFile.create_file("xiaohui.jpg");     // create a new jpeg file
byte a[32];
     SendResetCmd();
     delay(4000);                            //Wait 2-3 second to send take picture command
      SendTakePhotoCmd();
     while(mySerial.available()>0)
        incomingbyte=mySerial.read();
     TestFile.open();
      while(!EndFlag)
         j=0;
         k=0;
         count=0;
         SendReadDataCmd();
         delay(20);
               k++;
               if((k>5)&&(j<32)&&(!EndFlag))
               a[j]=incomingbyte;
               if((a[j-1]==0xFF)&&(a[j]==0xD9))     //tell if the picture is finished
               EndFlag=1;
               j++;
	       count++;
        for(j=0;j<count;j++)
        {   if(a[j]<0x10)
         Serial.print("0");
        Serial.print(a[j],HEX);           // observe the image through serial port
         Serial.print(" ");
          TestFile.write((char*)a);
         i++;
    TestFile.close();
   Serial.print("Finished writing data to file");
     while(1);
void SendResetCmd()
      mySerial.write((byte)0x56);
      mySerial.write((byte)0x00);
      mySerial.write((byte)0x26);
      mySerial.write((byte)0x31);
      mySerial.write((byte)0x05);
      mySerial.write((byte)0x04);
      mySerial.write((byte)0x01);
      mySerial.write((byte)0x19);
      mySerial.write((byte)0x11);
      mySerial.write((byte)0x24);
      mySerial.write((byte)0x03);
      mySerial.write((byte)0xAE);
      mySerial.write((byte)0xC8);
      mySerial.write((byte)0x36);
      MH=a/0x100;
      ML=a%0x100;
      mySerial.write((byte)0x32);
      mySerial.write((byte)0x0c);
      mySerial.write((byte)0x0a);
      mySerial.write((byte)MH);
      mySerial.write((byte)ML);
      mySerial.write((byte)0x20);
      a+=0x20;
You should change your FAT16 libary to an uptodate version.
All WConstants.h did was #include "wiring.h", but yes, as Grumpy Mike says, you should update.
