arduino 1.0 and avrispmkii
i need to program an atmega328pu chip on a breadboard. i followed every instruction on the website and everything i found on the internet but every time i burn the code to the chip i get an error message
(attached), even if i have selected the correct comm port and board =(
Turn on verbose upload output in Prefernces:
Show verbose output during: [ ] copilation [x] upload.
Then when you upload you will get MUCH more detail, including the signature that was actually read. If the signature is reading as 00 00 00 or FF FF FF you probably have something connected incorrectly.
If you have a '328-PU vs a '328P-PU, that would explain the signature byte mismatch.
Find your copy of avrdude.conf and paste this at the end of it
# ATmega328P
part
    id            = "m328";
    desc      = "ATMEGA328";
    has_debugwire = yes;
    flash_instr       = 0xB6, 0x01, 0x11;
    eeprom_instr  = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
              0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
              0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode    = 0x86;
    # avr910_devcode  = 0x;
    signature     = 0x1e 0x95 0x14;
    pagel     = 0xd7;
    bs2           = 0xc2;
    chip_erase_delay  = 9000;
    pgm_enable = "1 0 1 0 1 1 0 0 0 1 0 1 0 0 1 1",
         "x x x x x x x x x x x x x x x x";
    chip_erase = "1 0 1 0 1 1 0 0 1 0 0 x x x x x",
    timeout   = 200;
    stabdelay = 100;
    cmdexedelay   = 25;
    synchloops    = 32;
    bytedelay = 0;
    pollindex = 3;
    pollvalue = 0x53;
    predelay  = 1;
    postdelay = 1;
    pollmethod    = 1;
    pp_controlstack =
    0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
    0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
    0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
    0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay  = 100;
    progmodedelay = 0;
    latchcycles       = 5;
    togglevtg     = 1;
    poweroffdelay = 15;
    resetdelayms  = 1;
    resetdelayus  = 0;
    hvleavestabdelay  = 15;
    resetdelay        = 15;
    chiperasepulsewidth   = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    memory "eeprom"
    paged       = no;
    page_size   = 4;
    size        = 1024;
    min_write_delay = 3600;
    max_write_delay = 3600;
    readback_p1 = 0xff;
    readback_p2 = 0xff;
    read = " 1 0 1 0 0 0 0 0",
           " 0 0 0 x x x a9 a8",
           " a7 a6 a5 a4 a3 a2 a1 a0",
           " o o o o o o o o";
    write = " 1 1 0 0 0 0 0 0",
        " i i i i i i i i";
    loadpage_lo = " 1 1 0 0 0 0 0 1",
              " 0 0 0 0 0 0 0 0",
              " 0 0 0 0 0 0 a1 a0",
              " i i i i i i i i";
    writepage = " 1 1 0 0 0 0 1 0",
            " 0 0 x x x x a9 a8",
            " a7 a6 a5 a4 a3 a2 0 0",
            " x x x x x x x x";
    mode        = 0x41;
    delay       = 20;
    blocksize   = 4;
    readsize    = 256;
    memory "flash"
    paged       = yes;
    size        = 32768;
    page_size   = 128;
    num_pages   = 256;
    min_write_delay = 4500;
    max_write_delay = 4500;
    readback_p1 = 0xff;
    readback_p2 = 0xff;
    read_lo = " 0 0 1 0 0 0 0 0",
          " 0 0 a13 a12 a11 a10 a9 a8",
          " o o o o o o o o";
    read_hi = " 0 0 1 0 1 0 0 0",
          " o o o o o o o o";
    loadpage_lo = " 0 1 0 0 0 0 0 0",
              " 0 0 0 x x x x x",
              " x x a5 a4 a3 a2 a1 a0",
              " i i i i i i i i";
    loadpage_hi = " 0 1 0 0 1 0 0 0",
              " 0 0 0 x x x x x",
              " i i i i i i i i";
    writepage = " 0 1 0 0 1 1 0 0",
            " a7 a6 x x x x x x",
            " x x x x x x x x";
    mode        = 0x41;
    delay       = 6;
    blocksize   = 128;
    readsize    = 256;
    memory "lfuse"
    size = 1;
    read = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
           "x x x x x x x x o o o o o o o o";
    write = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
             "x x x x x x x x i i i i i i i i";
    memory "hfuse"
    size = 1;
    read = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
    write = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
    size = 1;
    read = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
           "x x x x x x x x x x x x x o o o";
    write = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
             "x x x x x x x x x x x x x i i i";
    memory "lock"
    size = 1;
    read = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
           "x x x x x x x x x x o o o o o o";
    write = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
             "x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
    size = 1;
    read = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
           "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
    size = 3;
    read = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
           "x x x x x x a1 a0 o o o o o o o o";
now find your copy of boards.txt and copy this to the end
uno328.name=Arduino Uno with '328
uno328.upload.protocol=arduino
uno328.upload.maximum_size=32256
uno328.upload.speed=115200
uno328.bootloader.low_fuses=0xff
uno328.bootloader.high_fuses=0xde
uno328.bootloader.extended_fuses=0x05
uno328.bootloader.path=optiboot
uno328.bootloader.file=optiboot_atmega328.hex
uno328.bootloader.unlock_bits=0x3F
uno328.bootloader.lock_bits=0x0F
uno328.build.mcu=atmega328
uno328.build.f_cpu=16000000L
uno328.build.core=arduino
uno328.build.variant=standard
Restart the IDE - a new board type of Uno328 should be in the list, use that. There may be another step needed, if this doesn't work we'll see if someone else can advise on the process.
Thank you for your reply, i did everything but i get the error message "MCU 'atmega328' supported for assembler only
Yes, I tried that myself last night & got the same. Am trying to add a bunch of chips, all worked great except the '328 and a '16U4 (smaller memory version of Leonardo 32U4). Am looking into it.
