Arduino 1.0 no longer works for RTC RX8025
Hello
I’m using Seeeduino Stalker v2 and have recently switched to Arduino 1.0 but now I’m unable to read out my I2C RTC RX8025.
Using the “Wire->Master_reader” example I have a basic version which works for 0.23 but not voor 1.0:
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
Wire.requestFrom(0x32, 8 ); // request 6 bytes from slave device #2
while(Wire.available()) // slave may send less than requested
#if ARDUINO >= 100
char c = Wire.read();
#else
char c = Wire.receive(); // receive a byte as character
#endif
Serial.print(c, HEX); // print the character
Serial.println("");
On the other hand, the I2C tmp102 temperature sensor still works!
Greetings
Joris
I’m having the same problem. Did you get this figured out?
Have you checked - http://arduino.cc/en/Main/ReleaseNotes - ?
* The Wire library has also been modified to use the standard read() and * write() functions instead of send() and receive(). You can also use* * print() and println() for outgoing data.*
furthermore:
If the code is in conflict with the comments==> code wins ...
IF you hardcode for 1.0 (without the #if) does it work ?
// I saw it done this way ... #if defined(ARDUINO) && ARDUINO >= 100
@indyeric, I've not been able to get it working. I switched to the newer Seeeduino Stalker v2.1 wich uses another RTC that works with Arduino-1.0.
@robtillaart, I tried with hardcoded 1.0 code, if my defines were wrong, the compiler would complain about the old receive() method.
