Arduino 1.8.12 stk issues
Im a bit confused. It seems like it wont sync. First time i'm ever using anything like this. Any help would be appreciated
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 2242 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 1250 bytes (61%) of dynamic memory, leaving 798 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Rinni\AppData\Local\Temp\arduino_build_83438/firmware.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xcc
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xcc
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
As mentioned in the output, for troubleshooting suggestions have a look at:
does it work with 1.8.11?
