Arduino: 1.8.12 (Windows 7), Board: "Arduino Uno" C:\Users\JOM\Documents\Arduin
// commands for reading/sending data to a SHTx sensor
// send a command to the SHTx sensor
void sendCommandSHT(int command, int dataPin, int clockPin)
int ack;
// transmission start
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);
digitalWrite(clockPin, HIGH);
digitalWrite(dataPin, LOW);
digitalWrite(clockPin, LOW);
// shift out the command (the 3 MSB are address and must be 000, the last 5 bits are the command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// verify we get the right ACK
pinMode(dataPin, INPUT);
ack = digitalRead(dataPin);
if (ack != LOW)
Serial.println("ACK error 0");
if (ack != HIGH)
Serial.println("ACK error 1");
// wait for the SHTx answer
void waitForResultSHT(int dataPin)
int ack;
for (int i = 0; i < 100; ++i)
delay(10);
if (ack == LOW)
if (ack == HIGH)
Serial.println("ACK error 2");
// get data from the SHTx sensor
int getData16SHT(int dataPin, int clockPin)
int val;
// get the MSB (most significant bits)
val = shiftIn(dataPin, clockPin, MSBFIRST, 8, 3);
val *= 256; // this is equivalent to val << 8;
// send the required ACK
// get the LSB (less significant bits)
val |= shiftIn(dataPin, clockPin, MSBFIRST, 8, 3); << this is the error line
return val;
// skip CRC data from the SHTx sensor
void skipCrcSHT(int dataPin, int clockPin)
i got this error today while trying to upload the code, can you help me find the wrong code??
thank you before
The built-in 'shiftIn' function takes THREE parameters hence why you are getting an error since you are passing too many arguments to it.
  int ack;
  if (ack != LOW)
  if (ack != HIGH)
  int ack;
    delay(10);
    if (ack == LOW)
  if (ack == HIGH)
  int val;
  val = shiftIn(dataPin, clockPin, MSBFIRST);
  val |= shiftIn(dataPin, clockPin, MSBFIRST);
  return val;
hope that helps....
