Help
I can't burn a bootloader for attiny85 boards. I am trying to use them in a serial rs485 project and the bootloader cannot be burned.
I have tried all day and used veraious methods with the USBASP v2 and using an Arduino Zero clone and cannot get attiny85 to work with serial or accept a bootloader.
Specifically I can flash micronucleus 16.5mhz onto it and make sketches with the digispark board selected but I cant update a bootloader for 8mhz or 16mhz and it is always 16.5 or the mystery factory bootloader.
I also tried the adafruit trinket but to no avail.
my setup is window$ with usb 1.1 port being used (not even 2.0 but I have 3.0 and dont use them)
I am using a USBASP which can burn micronucleus using the avrdudeGUI
but I cannot find or get the other firmware files in arduino ide to try to burn them.
I keep getting this error:
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Snapduino, 8 MHz"
C:\Users\trusted\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\trusted\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -v -v -v -pattiny85 -cusbasp -Pusb -e -Uefuse:w:0xfe:m -Uhfuse:w:0xd7:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3, compiled on Feb 17 2016 at 09:25:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\trusted\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
avrdude: error at C:\Users\trusted\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf:1133: programmer type jtagice3_updi not found
avrdude: error reading system wide configuration file "C:\Users\trusted\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Error while burning bootloader.
I also noticed that the libraries available are now "per board" and this completely breaks a lot of things and requires way too much copy and paste. Is there anything that can make this easier or should I be using an older adruino ide?
