Hello, this is my first post and my first arduino project. The sketch is a known working sketch that I got from a fellow enthusiast that programmed it to automatically open a convertible car top. It has been used by dozens of other owners so I know the sketch is good.
Here is my situation. I purchased a nano and downloaded the IDE. I compiled the sketch and tried to upload to the Nano board. I get the following:
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FamilyPC\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092 -warnings=none -build-cache C:\Users\FamilyPC\AppData\Local\Temp\arduino_cache_687970 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\FamilyPC\Documents\Arduino_986AutoTop_v0_1_986AutoTop_v0_1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\FamilyPC\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092 -warnings=none -build-cache C:\Users\FamilyPC\AppData\Local\Temp\arduino_cache_687970 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\FamilyPC\Documents\Arduino_986AutoTop_v0_1_986AutoTop_v0_1.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\sketch_986AutoTop_v0_1.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\sketch_986AutoTop_v0_1.ino.cpp" -o "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\sketch_986AutoTop_v0_1.ino.cpp" -o "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\sketch_986AutoTop_v0_1.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/_986AutoTop_v0_1.ino.elf" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092\sketch_986AutoTop_v0_1.ino.cpp.o" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/..\arduino_cache_687970\core\core_arduino_avr_nano_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/_986AutoTop_v0_1.ino.elf" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/_986AutoTop_v0_1.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/_986AutoTop_v0_1.ino.elf" "C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/_986AutoTop_v0_1.ino.hex"
Sketch uses 1698 bytes (5%) of program storage space. Maximum is 30720 bytes.
Global variables use 19 bytes (0%) of dynamic memory, leaving 2029 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\FamilyPC\AppData\Local\Temp\arduino_build_787092/_986AutoTop_v0_1.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x94
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Of note, If I change the board to Mini, it uploads but the board is actually a Nano.
Thanks in advance.
John
