I have a question to solve this problem in MacBook
Arduino: 1.8.6 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 1164 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/hong-gihun/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/hong-gihun/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.SOC -b115200 -D -Uflash:w:/var/folders/c3/_3c81nwn19g50jj6826h7hgr0000gn/T/arduino_build_496875/sketch_mar08c.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/hong-gihun/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/hong-gihun/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.SOC
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I followed the procedure to solve this problem ( Uncheck Compilation and check the upload on 'show verbose output during' )
Also, I attach the code
int led_pin = 6;
//Declaring LED pin as output
pinMode(led_pin, OUTPUT);
//Fading the LED
for(int i=0; i<255; i++){
analogWrite(led_pin, i);
delay(5);
for(int i=255; i>0; i--){
delay(5);
