Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Warning: Board gizduino-:avr:Gizduino168 doesn't define a 'build.board' preference. Auto-set to: AVR_GIZDUINO168
Warning: Board gizduino-:avr://MiniUSB168 doesn't define a 'build.board' preference. Auto-set to: AVR_//MINIUSB168
Warning: Board gizduino-:avr:MiniUSB168 doesn't define a 'build.board' preference. Auto-set to: AVR_MINIUSB168
Build options changed, rebuilding all
C:\Users\Anchita\Documents\Arduino\libraries\LiquidCrystal\I2CIO.cpp:35:26: fatal error: ../Wire/Wire.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
These steps may also save you some unnecessary time and effort in the forum.
Always provide as much detail as possible to your issue it may be important.
If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
If applicable provide a schematic even if hand drawn.
Pictures are an invaluable aid. See THIS TOPIC for help posting them.
COMMON ISSUES
Check you have a COMMON GROUND where required.
Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
Try other computers where possible.
Try other USB leads where possible.
You may not have the correct driver installed. CH340/341 or CP2102
There may be a problem with the board check your wiring first.
Remove any items connected to pins 0 and 1.
COMPUTER RELATED
Ensure you turn off any additional security / antivirus just to test.
There may be a problem with the PC try RESTARTING it.
You may be selecting the wrong COM port.
Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
Clear your browsers CACHE.
If using CREATE then try an INCOGNITO window or similar to rule out browser add-on's.
Close the IDE before using any other serial programs.
Preferably install IDE's as ADMINISTRATOR or your OS equivalent
If you have tried multiple IDE's then you may need to perform additional clean up.
Performing the above actions may help resolve your problem without further help.
Bob.
