Arduino 101 BLE using "sandeepmistry/arduino-BLEPeripheral'
Hi, all.
I’m trying to use the library “arduino-BLEPeripheral” on
instead of CurieBLE to program my Arduino 101.
My problem is that the constructor of class BLEperipheral in “arduino-BLEPeripheral” has three parameters indicates the pins connected to the BLE module, while the constructor of class BLEperipheral in CurieBLE has no parameter.
Is it possible to use “arduino-BLEPeripheral” for the on-board BLE on Arduino 101?
// Import libraries (BLEPeripheral depends on SPI)
#include <SPI.h>
#include <BLEPeripheral.h>
// define pins (varies per shield/board)
#define BLE_REQ   10
#define BLE_RDY   2
#define BLE_RST   9
// create peripheral instance, see pinouts above
BLEPeripheral blePeripheral = BLEPeripheral(BLE_REQ, BLE_RDY, BLE_RST);
// uuid's can be:
//   16-bit: "ffff"
//  128-bit: "19b10010e8f2537e4f6cd104768a1214" (dashed format also supported)
// create one or more services
BLEService service = BLEService("fff0");
// create one or more characteristics
BLECharCharacteristic characteristic = BLECharCharacteristic("fff1", BLERead | BLEWrite);
// create one or more descriptors (optional)
BLEDescriptor descriptor = BLEDescriptor("2901", "value");
#if defined (__AVR_ATmega32U4__)
  delay(5000);  //5 seconds delay for enabling to see the start up comments on the serial board
#endif
  blePeripheral.setLocalName("local-name"); // optional
  blePeripheral.setAdvertisedServiceUuid(service.uuid()); // optional
  // add attributes (services, characteristics, descriptors) to peripheral
  blePeripheral.addAttribute(service);
  blePeripheral.addAttribute(characteristic);
  blePeripheral.addAttribute(descriptor);
  // set initial value
  characteristic.setValue(0);
  // begin initialization
  blePeripheral.begin();
  BLECentral central = blePeripheral.central();
  if (central) {
    // central connected to peripheral
    Serial.print(F("Connected to central: "));
    Serial.println(central.address());
    while (central.connected()) {
      // central still connected to peripheral
      if (characteristic.written()) {
        // central wrote new value to characteristic
        Serial.println(characteristic.value(), DEC);
        // set value on characteristic
        characteristic.setValue(5);
    // central disconnected
    Serial.print(F("Disconnected from central: "));
starter.ino (1.96 KB)
