I have arduino 101 (curie) , when I try bluetooth sample sketch (batterymonitor) , arduino 101 hangs,I do not see even messages printed to Serial port using serial.println,this is first satement after serial.begin statement
I have tried on MAC OS X (arduino IDE 1.6.8) ,windows 8(64 bit,arduino IDE 1.6.7) same result (hang)
What is the bluetooth device that are you connecting to the Arduino 101?
Change the start of your setup loop to be:
Serial.begin(9600); // initialize Serial communication
while (!Serial); // wait for the serial port to open
pinMode(13, OUTPUT); // initialize the LED on pin 13 to indicate when a central is connected
Re load your sketch. Open the Serial monitor.
If you DO NOT see "Bluetooth device active, waiting for connections...", then there is a problem with you Arduino 101 or the Serial connection to it.
If you DO see "Bluetooth device active, waiting for connections...", but nothing else after connecting - then I suspect an issue with the smartphone or whatever you are connecting with.
