I am currently attempting to run a sketch on an Arduino 101 embedded on a Udoo board. The Udoo is running Ubuntu 18.04.2 LTS Bionic. Web browser is Mozilla Firefox 66.0.5.
I attempted to run through the Arduino IDE but it did not have my board listed and therefore would not connect. My next step was to try running through Arduino Create as it has the cores for all boards. I installed the plugin and entered a simple sketch from a tutorial: Basic Lesson – Voltage Sensor Module « osoyoo.com
When I try to "Upload and Save" a notification pops up that says "Arduino/Genuino 101 Disconnected" and the error: Executing command: exec: not started. Another status then pops up that says "Arduino/Genuino 101 Connected". The output window shows:
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn Intel:arc32:arduino_101 -build-cache /tmp -build-path /tmp/638114960/build -verbose -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/Intel/tools/openocd/0.9.0+0.1 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/industruino/tools/bossac/1.7.0-industruino -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -libraries /tmp/638114960/custom -libraries /tmp/638114960/pinned /tmp/638114960/sketch_may15a
Sketch uses 17632 bytes (11%) of program storage space. Maximum is 155648 bytes.
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[/dev/ttyACM0]
Touching port /dev/ttyACM0 at 1200bps
Set DTR off
Flashing with command:/home/myuser/.arduino-create/Intel/arduino101load/2.1.0/arduino101load -dfu=/home/myuser/.arduino-create/arduino/dfu-util/0.9.0-arduino1 -bin=/tmp/arduino-create-agent547521223/sketch_may15a.bin -port=/dev/ttyACM0 -v -ble_fw_str=ATP1BLE00R-1631C4439 -ble_fw_pos=169984 -rtos_fw_str= -rtos_fw_pos=0 -core=2.0.0
Set DTR off
Flashing with command:/home/dendemo/.arduino-create/Intel/arduino101load/2.1.0/arduino101load -dfu=/home/dendemo/.arduino-create/arduino/dfu-util/0.9.0-arduino1 -bin=/tmp/arduino-create-agent547521223/sketch_may15a.bin -port=/dev/ttyACM0 -v -ble_fw_str=ATP1BLE00R-1631C4439 -ble_fw_pos=169984 -rtos_fw_str= -rtos_fw_pos=0 -core=2.0.0
