Arduino 101 Libraries [SOLVED]
Hello,
I'm looking forward to include this new arduino in a project I was developing, as the project required BLE and probably a gyroscope.
But, before purchasing:
-Is this arduino compatible with the standard libraries? (I need to use the Servo library)
-Have the libraries of the Bluetooth system been published? (I need to use the BLE library)
-Do others libraries, such as the Arduino New Ping library, work? (I need to use ultrasonic sensors)
If not, when will this services be available?
And, how difficult can be a library to modify? I mean, if NewPing is the only library not working for instance, I could consider modifying it.
I need this project done by march, and I need to start working with the libraries by february.
Thanks for the support,
edsa ;).
Hi edsa,
standard libraries have been ported, BLE library is ready and compatible with sandeep's BLE lib (ArduinoCore-arc32/libraries at master · arduino/ArduinoCore-arc32 · GitHub).
NewPing seems compatible since it has support for Due and Zero but I should take a closer look
Can i use the sandeep's BLE library instead curieBLE?
In curieBLE actions BlePeripheral.end() and .disconnect() doesn't work.
Thanks.
