ARDUINO 101 - multiple source files
Hi People,
short question: i want to separate my .ino file into multiple source files for the sake of the better code overview.
I have menaged to separate global variables and functions that doesnt depend on any external library.
When i want to include for example Wire, Serial or Magwick in header file of his own source file i encounter difficulties by creating an object in same soruce file.
Header
//senzoriFun.h
#ifndef GLOBAL_H
#include "global.h"
#endif
#ifndef MADGWICKAHRS_H
#include <MadgwickAHRS.h>
#endif
#ifndef CURIEIMU_H
#include <CurieIMU.h>
#endif
#ifdef __cplusplus
extern "C" {
#endif
void prikaz();
#ifdef __cplusplus
#endif
Source
//senzoriFun.c
#include "senzoriFun.h"
Madgwick filter; //creating object
void prikaz(){
common error messages refers to both library:
error: unknown type name ‘class’
error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘:’ token
for info: every source file.c and own header file.h is located in one folder with main.ino
Thanks in advance
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here using code tags.
Following error message:
Arduino: 1.8.2 (Windows 10), Board: "Arduino/Genuino 101"
In file included from sketch\senzoriFun.h:7:0,
                 from sketch\senzoriFun.c:1:
C:\Users\Tibor\Documents\Arduino\libraries\Madgwick\src/MadgwickAHRS.h:23:1: error: unknown type name 'class'
 class Madgwick{
C:\Users\Tibor\Documents\Arduino\libraries\Madgwick\src/MadgwickAHRS.h:23:15: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
 class Madgwick{
In file included from C:\Users\Tibor\AppData\Local\Arduino15\packages\Intel\hardware\arc32\2.0.2\libraries\CurieIMU\src/CurieIMU.h:25:0,
                 from sketch\senzoriFun.h:11,
C:\Users\Tibor\AppData\Local\Arduino15\packages\Intel\hardware\arc32\2.0.2\libraries\CurieIMU\src/BMI160.h:478:1: error: unknown type name 'class'
 class BMI160Class {
C:\Users\Tibor\AppData\Local\Arduino15\packages\Intel\hardware\arc32\2.0.2\libraries\CurieIMU\src/BMI160.h:478:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
 class BMI160Class {
In file included from sketch\senzoriFun.h:11:0,
C:\Users\Tibor\AppData\Local\Arduino15\packages\Intel\hardware\arc32\2.0.2\libraries\CurieIMU\src/CurieIMU.h:93:1: error: unknown type name 'class'
 class CurieIMUClass : public BMI160Class {
C:\Users\Tibor\AppData\Local\Arduino15\packages\Intel\hardware\arc32\2.0.2\libraries\CurieIMU\src/CurieIMU.h:93:21: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
C:\Users\Tibor\AppData\Local\Arduino15\packages\Intel\hardware\arc32\2.0.2\libraries\CurieIMU\src/CurieIMU.h:250:1: error: unknown type name 'CurieIMUClass'
 extern CurieIMUClass CurieIMU;
senzoriFun.c:3: error: unknown type name 'Madgwick'
exit status 1
option enabled in File -> Preferences.
Tnx!
It seems like the library is being interpreted as C (which doesn’t support classes) instead of C++ (which does). Try renaming senzoriFun.c to senzoriFun.cpp. Most of the Arduino library code you will find is C++.
Thanks very much!
That solved me a Problem
Best regards / Mit freundlcihen Grüßen / Sve najbolje !
