Sketch uses 17,244 bytes (11%) of program storage space. Maximum is 155,648 bytes.
C:\Users\William\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.24/arduino101load/arduino101load C:\Users\William\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.24/x86/bin C:\Users\William\AppData\Local\Temp\build9c9ef3bdfe2fccb480bc6e4bac749e41.tmp/Blink.ino.bin COM4 verbose
java.io.IOException: Cannot run program “C:\Users\William\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.24/arduino101load/arduino101load”: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:130)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:209)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.Sketch.upload(Sketch.java:1187)
at processing.app.Sketch.exportApplet(Sketch.java:1160)
at processing.app.Sketch.exportApplet(Sketch.java:1132)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
at java.lang.ProcessImpl.create(Native Method)
at java.lang.ProcessImpl.(ProcessImpl.java:386)
at java.lang.ProcessImpl.start(ProcessImpl.java:137)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 9 more
An error occurred while uploading the sketch
I found the problem. Java can not find the file "arduino101load". It was not installed with the 1.6.10 build. Found where McAfee would not let it load.
Hi wfwbrw,
this is a common problem with arduino101-load. It's clearly a false positive (the source code is here) but most antivirus are still not whitelisting it.
One solution can be reinstalling core 1.0.6 and whitelisting the arduino101-load executable before running it. Hope it helps
Forcing reset using 1200bps open/close on port COM5
C:\Users\Dave\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.24/arduino101load/arduino101load C:\Users\Dave\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.24/x86/bin C:\Users\Dave\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp/Blink.ino.bin COM5 verbose
Starting download script...
Args to shell: [C:\Users\Dave\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.24/x86/bin C:\Users\Dave\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp/Blink.ino.bin COM5 verbose]
Serial Port: COM5
BIN FILE C:\Users\Dave\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp/Blink.ino.bin
Waiting for device...
Flashing is taking longer than expected
Try pressing MASTER_RESET button
ERROR: Device is not responding.
option enabled in File -> Preferences.
I've pressed the RESET button a number of times. The USB "disconnect/connect" sound is played 3 or 4 timer and the errors are displayed.
I've been trying to get this going for 6 hours now and I feel a beer coming on!
Any idea what I can do?
Interesting that the root cause of this problem for the Intel enhanced Arduino 101 not working is that a required executable file for Windows IDE operation is flagged by the McAfee virus tool (owned by Intel) as a virus and it is not yet whitelisted in the standard McAfee virus definition updates. Time to escalate to marketing, as the kids are not playing well together.
