Hello
A lot of industrial communication is done using 12v instead of 5v, not sure why but it is that way.
From what i have heard very little amps but 12v, as a power for signal only .
I was thinking i need to interface a machine that uses 12v; in its bus it also provides +12v and ground, if i connect other pins to this 12v it performs some actions.
One way of doing this would be using relays, i think their safe to use and prevent wrong currents into the arduino.
Might it also be possible to connect the ground of the bus to the arduino ground; and use transistor ( or mosfet? ) so that an arduino pin out triggers the fet with 5v (well perhaps put a resistor for less there) and then the transistor would connect my device bus ? (perhaps put in a diode too, to prevent against wrong currents. (what kind of transistor / mosfet should i use?)
