I'm not sure if this is the best place to post a bug, but I have found that version 2.0.4 completely froze on Windows 10 because a dvd with sample code was not present. It appears that the software was trying to restore the previous session when I was looking at the code but since the file was't present (dvd removed) it froze. Nothing was displayed on the screen and I had to shut it down through task manager. I saw errors running it in a Powewrshell window where I saw the errors while it tried to restore the session. Putting the dvd back in the drive allowed it load normally.
I installed the code using your installer for Windows 10.
Through searching for the cause I found another example complaining of the same problem but the file was located remotely I believe. In any case, the program has an annoying bug that takes some time to sort out and seems out of place in a release version.
