I am using mac book pro M1. I just installed the ESP8266 library and used the example code. But just after the closing of IDE, The example codes are gone but others things are okay. What is the problem?
Hi, Arduino 2.0 is still in beta, so that issue still could be an outstanding issue. There is a forum section set aside to report possible problems with beta versions. Do a search for the issue and if not found, go ahead and report the problem. Make sure you provide steps that will reproduce the problem
Thanks
ok. thank you very much for your reply
Please provide a specific example of an "example code" that was affected.
Please provide a detailed description of what you mean by "gone".
- What did you do?
- What were the results you expected from doing that?
- What were the results you observed that did not match your expectations?
- Make sure to include the full and exact text of any error or warning message you might have encountered.
I figured out the problem last night! Its working now! Thank you very much!
I'm glad to hear it's working now. Thank you for taking the time to post an update.
