Hey guys,
I would like to control a fan via a website.
I did a project a long time ago in which I implemented something like this for an aquarium. My index.html file is still from that time.
Now I would like to call it up in my current sketch.
What works:
- serial output of the temperature (i.e. the temperature sensor works)
- fan
- Output of a website, but not my index.html file (see screenshot)
This website should be replaced by the index.html file.
I was also able to upload the index file to the esp using the uploader plugin. this also worked. at the same time, I also uploaded a text file for testing and was able to read it out using a test sketch. so the index.html should also exist in the littlefs file system.
How do I call it up in my sketch?
// Lolin: Fan läuft im Wechsel hoch und runter, Sensor funktioniert
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include "LittleFS.h"
#define LED1 5
#define FAN1 25
#define PWM_CH_LED 0
#define PWM_CH_FAN 1
#define PWM_RES 8
const int MAX_DC = (int)(pow(2, PWM_RES) - 1);
int fanstate = 0;
// GPIO where the DS18B20 is connected to
const int oneWireBus = 33;
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(oneWireBus);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
//Variable to store RPM or fan state
//String fanstate = "";
// Variables to store temperature values
String temperatureF = "";
String temperatureC = "";
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;
// Replace with your network credentials
const char *ssid = "fritzboxdampf";
const char *password = "mnghfjmghjkgh";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readDSTemperatureC() {
// Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
sensors.requestTemperatures();
float tempC = sensors.getTempCByIndex(0);
if (tempC == -127.00) {
Serial.println("Failed to read from DS18B20 sensor");
return "--";
Serial.print("Temperature Celsius: ");
Serial.println(tempC);
return String(tempC);
String readDSTemperatureF() {
float tempF = sensors.getTempFByIndex(0);
if (int(tempF) == -196) {
return "--";
Serial.print("Temperature Fahrenheit: ");
Serial.println(tempF);
return String(tempF);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/6.5.2/css/all.min.css">
<style>
html {
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 3.0rem; }
.units { font-size: 1.2rem; }
.ds-labels{
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>Hoymiles Temp/Fan Monitor</h2>
<p>
<i class="fa-solid fa-temperature-half" style="color:#059e8a;"></i>
<span class="ds-labels">Temperature </span>
<span id="temperaturec">%TEMPERATUREC%</span>
<sup class="units">°C</sup>
</p>
<p>
<i class="fa-solid fa-fan" style="color:#059e8a;"></i>
<span class="ds-labels">Fan-State</span>
<span id="temperaturef">%TEMPERATUREF%</span>
<sup class="units">%</sup>
</p>
<p>
</p>
<form action="/get">
Temperatur 50%: <input type="time" name="start50">
<input type="submit" value="Submit">
</form><br>
Temperatur 100%: <input type="time" name="start100">
</form><br>
Automatik AN: <input type="radio" name="activate" value="on"><br>
Automatik AUS: <input type="radio" name="activate" value="off"><br>
</form>
<label for="illumination">Manuelle Steuerung:</label>
<select id="illumination" name="illumination">
<option value="0">off</option>
<option value="25">25%</option>
<option value="50">50%</option>
<option value="75">75%</option>
<option value="100">100%</option>
</select>
</form>
</body>
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperaturec").innerHTML = this.responseText;
xhttp.open("GET", "/temperaturec", true);
xhttp.send();
}, 10000) ;
document.getElementById("temperaturef").innerHTML = this.responseText;
xhttp.open("GET", "/temperaturef", true);
xhttp.send();
}, 10000) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DS18B20 values
String processor(const String &var) {
//Serial.println(var);
if (var == "TEMPERATUREC") {
return temperatureC;
} else if (var == "TEMPERATUREF") {
return temperatureF;
return String();
if (!LittleFS.begin()) {
Serial.println("An Error has occurred while mounting LittleFS");
return;
File file = LittleFS.open("/test_example.txt", "r");
if (!file) {
Serial.println("Failed to open file for reading");
return;
Serial.println("File Content:");
while (file.available()) {
Serial.write(file.read());
file.close();
Serial.println("PWM Program");
// PWM CH 0 (LED)
// 5 kHz freq
// 8 bit resolution
// attached to GPIO 5
ledcSetup(PWM_CH_LED, 5000, PWM_RES);
ledcAttachPin(LED1, PWM_CH_LED);
// PWM CH 1 (FAN)
// 5 kHz freq
// 8 bit resolution
// attached to GPIO 25
ledcSetup(PWM_CH_FAN, 5000, PWM_RES);
ledcAttachPin(FAN1, PWM_CH_FAN);
delay(3000);
// kick start the FAN
ledcWrite(PWM_CH_FAN, MAX_DC);
Serial.print("MAX_DC: ");
Serial.println(MAX_DC);
// Start up the DS18B20 library
sensors.begin();
temperatureC = readDSTemperatureC();
temperatureF = readDSTemperatureF();
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi");
Serial.print(".");
// Print ESP Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send_P(200, "text/html", index_html, processor);
server.on("/html", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send(LittleFS, "/index.html", "text/html");
server.on("/temperaturec", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send_P(200, "text/plain", temperatureC.c_str());
server.on("/temperaturef", HTTP_GET, [](AsyncWebServerRequest *request) {
request->send_P(200, "text/plain", temperatureF.c_str());
// Start server
server.begin();
if ((millis() - lastTime) > timerDelay) {
lastTime = millis();
if (fanstate == 0) {
fanON();
fanOFF();
delay(5000);
void fanON() {
Serial.println("enable fan");
uint8_t i;
for (i = 0; i < MAX_DC; i++) {
ledcWrite(PWM_CH_LED, i);
ledcWrite(PWM_CH_FAN, i);
delay(30);
fanstate = 1;
Serial.println(i);
void fanOFF() {
Serial.println("disable fan");
uint8_t i;
for (i = 255; i > 0; i--) {
delay(30);
fanstate = 0;
Serial.println(i);
