Arduino 2.3.2 won't open
Using Windows 10. The familiar stuck on the pulsing Arduino logo problem
Here's the log file:
PS C:\Program Files\Arduino IDE> & ".\arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 20300
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Hank/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-06-24T08:27:51.114Z root INFO Backend Object.initialize: 4.4 ms [Finished 0.530 s after backend start]
2024-06-24T08:27:51.115Z root INFO Backend Object.configure: 3.6 ms [Finished 0.531 s after backend start]
2024-06-24T08:27:51.115Z root INFO Backend s.onStart: 2.0 ms [Finished 0.531 s after backend start]
2024-06-24T08:27:51.115Z root INFO Backend s.configure: 0.4 ms [Finished 0.555 s after backend start]
2024-06-24T08:27:51.116Z root INFO Backend d.onStart: 0.2 ms [Finished 0.555 s after backend start]
2024-06-24T08:27:51.117Z root INFO Backend d.configure: 0.1 ms [Finished 0.556 s after backend start]
2024-06-24T08:27:51.118Z root INFO Backend d.initialize: 24.9 ms [Finished 0.556 s after backend start]
2024-06-24T08:27:51.118Z root INFO Backend c.onStart: 0.2 ms [Finished 0.556 s after backend start]
2024-06-24T08:27:51.118Z root INFO Backend a.configure: 1.1 ms [Finished 0.557 s after backend start]
2024-06-24T08:27:51.120Z config INFO >>> Initializing CLI configuration...
2024-06-24T08:27:51.120Z root INFO Backend c.initialize: 0.6 ms [Finished 0.557 s after backend start]
2024-06-24T08:27:51.120Z root INFO Backend R.onStart: 0.8 ms [Finished 0.558 s after backend start]
2024-06-24T08:27:51.121Z config INFO Loading CLI configuration from c:\Users\Hank\.arduinoIDE\arduino-cli.yaml...
2024-06-24T08:27:51.122Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-06-24T08:27:51.122Z root INFO Backend a.initialize: 0.4 ms [Finished 0.559 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend w.onStart: 1.3 ms [Finished 0.560 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend r.configure: 2.0 ms [Finished 0.560 s after backend start]
2024-06-24T08:27:51.122Z discovery-log INFO start
2024-06-24T08:27:51.122Z discovery-log INFO start new deferred
2024-06-24T08:27:51.122Z root INFO Backend d.initialize: 0.6 ms [Finished 0.561 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend y.onStart: 2.1 ms [Finished 0.562 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend r.configure: 1.7 ms [Finished 0.562 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend a.onStart: 0.5 ms [Finished 0.564 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend h.configure: 0.4 ms [Finished 0.564 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend s.configure: 0.2 ms [Finished 0.564 s after backend start]
2024-06-24T08:27:51.122Z root INFO Backend l.configure: 0.1 ms [Finished 0.564 s after backend start]
2024-06-24T08:27:51.125Z root INFO Theia app listening on http://127.0.0.1:60151.
2024-06-24T08:27:51.125Z root INFO Finished starting backend application: 3.0 ms [Finished 0.567 s after backend start]
2024-06-24T08:27:51.125Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Hank/.arduinoIDE/plugins does not exist.
2024-06-24T08:27:51.125Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Hank/.arduinoIDE/extensions does not exist.
2024-06-24T08:27:51.126Z root WARN The local plugin referenced by local-dir:C:\Users\Hank\.arduinoIDE\plugins does not exist.
2024-06-24T08:27:51.136Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Hank\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Hank\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Hank\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-06-24T08:27:51.137Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-06-24T08:27:51.137Z config INFO Loaded the CLI configuration.
2024-06-24T08:27:51.150Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Hank/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Hank/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-06-24T08:27:51.150Z config INFO Validating the CLI configuration...
2024-06-24T08:27:51.151Z config INFO The CLI config is valid.
2024-06-24T08:27:51.151Z config INFO <<< Initialized the CLI configuration.
2024-06-24T08:27:51.168Z root INFO Resolve plugins list: 47.4 ms [Finished 0.610 s after backend start]
2024-06-24T08:27:51.303Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Using config file: c:\\Users\\Hank\\.arduinoIDE\\arduino-cli.yaml"
time="2024-06-24T04:27:51-04:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-06-24T04:27:51-04:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:60152
{"IP":"127.0.0.1","Port":"60152"}
2024-06-24T08:27:51.303Z daemon INFO Daemon is running.
2024-06-24T08:27:51.399Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Checking signature" index="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-06-24T04:27:51-04:00" level=info msg="Loading hardware from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading package ATTinyCore from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware"
time="2024-06-24T04:27:51-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="ATTinyCore:avr@1.5.2"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="ATTinyCore:micronucleus@2.5-azd1b"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading package STMicroelectronics from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="STMicroelectronics:stm32@2.6.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:CMSIS@5.7.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:STM32Tools@2.2.1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:xpack-arm-none-eabi-gcc@12.2.1-1.2"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:xpack-openocd@0.12.0-1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading package arduino from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-06-24T04:27:51-04:00" level=info msg="Missing signature file" index="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="arduino:mbed_rp2040@4.0.4"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.0.2"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@4.8.1-arduino5"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino18"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino2"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.10.0-arduino1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="arduino:rp2040tools@1.0.6"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading package builtin from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading package digistump from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="digistump:avr@1.6.7"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="digistump:micronucleus@2.0a4"
2024-06-24T08:27:51.402Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Loading package esp32 from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-06-24T08:27:51.468Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading package teensy from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
time="2024-06-24T04:27:51-04:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded platform" platform="teensy:avr@1.58.1"
time="2024-06-24T04:27:51-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
time="2024-06-24T04:27:51-04:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.58.0"
2024-06-24T08:27:51.472Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-06-24T08:27:51.475Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.6.0\\libraries" location=platform
time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries" location=platform
2024-06-24T08:27:51.490Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.2\\libraries" location=platform
time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.0.4\\libraries" location=platform
time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-06-24T08:27:51.538Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\libraries" location=platform
time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries" location=platform
time="2024-06-24T04:27:51-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\library_index.json"
2024-06-24T08:27:51.734Z daemon INFO time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\libraries" location=ide
time="2024-06-24T04:27:51-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\Documents\\Arduino\\libraries" location=user
2024-06-24T08:27:52.147Z root INFO Deploy plugins list: 47.4 ms [Finished 1.589 s after backend start]
2024-06-24T08:27:52.650Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-06-24T08:27:52.651Z daemon INFO time="2024-06-24T04:27:52-04:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-06-24T08:27:52.652Z daemon INFO time="2024-06-24T04:27:52-04:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2024-06-24T08:27:52.654Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-06-24T08:27:53.130Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 140.5 ms [Finished 1.882 s after frontend start]
2024-06-24T08:27:53.130Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-06-24T08:27:53.744Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking signature" index="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2024-06-24T08:27:53.746Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading hardware from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages"
2024-06-24T08:27:53.747Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package ATTinyCore from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware"
2024-06-24T08:27:53.752Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="ATTinyCore:avr@1.5.2"
2024-06-24T08:27:53.752Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\tools"
2024-06-24T08:27:53.752Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="ATTinyCore:micronucleus@2.5-azd1b"
2024-06-24T08:27:53.753Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package STMicroelectronics from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware"
2024-06-24T08:27:53.768Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="STMicroelectronics:stm32@2.6.0"
2024-06-24T08:27:53.768Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools"
2024-06-24T08:27:53.768Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:CMSIS@5.7.0"
2024-06-24T08:27:53.768Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:STM32Tools@2.2.1"
2024-06-24T08:27:53.768Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:xpack-arm-none-eabi-gcc@12.2.1-1.2"
2024-06-24T08:27:53.769Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="STMicroelectronics:xpack-openocd@0.12.0-1"
2024-06-24T08:27:53.769Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package arduino from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2024-06-24T08:27:53.770Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Missing signature file" index="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-06-24T08:27:53.772Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
2024-06-24T08:27:53.773Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="arduino:mbed_rp2040@4.0.4"
2024-06-24T08:27:53.774Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.0.2"
2024-06-24T08:27:53.774Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
2024-06-24T08:27:53.774Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
2024-06-24T08:27:53.774Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
2024-06-24T08:27:53.775Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@4.8.1-arduino5"
2024-06-24T08:27:53.775Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2024-06-24T08:27:53.775Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
2024-06-24T08:27:53.775Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino18"
2024-06-24T08:27:53.775Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino2"
2024-06-24T08:27:53.775Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
2024-06-24T08:27:53.776Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.10.0-arduino1"
2024-06-24T08:27:53.776Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2024-06-24T08:27:53.776Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
2024-06-24T08:27:53.776Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="arduino:rp2040tools@1.0.6"
2024-06-24T08:27:53.777Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package builtin from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\builtin"
2024-06-24T08:27:53.777Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
2024-06-24T08:27:53.777Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
2024-06-24T08:27:53.777Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
2024-06-24T08:27:53.778Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
2024-06-24T08:27:53.778Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
2024-06-24T08:27:53.778Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
2024-06-24T08:27:53.778Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
2024-06-24T08:27:53.778Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
2024-06-24T08:27:53.779Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package digistump from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware"
2024-06-24T08:27:53.781Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="digistump:avr@1.6.7"
2024-06-24T08:27:53.781Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\tools"
2024-06-24T08:27:53.781Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="digistump:micronucleus@2.0a4"
2024-06-24T08:27:53.782Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package esp32 from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
2024-06-24T08:27:53.821Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="esp32:esp32@2.0.11"
2024-06-24T08:27:53.821Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2024-06-24T08:27:53.821Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
2024-06-24T08:27:53.821Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.11.0-esp32-20221026"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@11.2_20220823"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-06-24T08:27:53.822Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s2-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-06-24T08:27:53.823Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-06-24T08:27:53.823Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loading package teensy from: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware"
2024-06-24T08:27:53.833Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding monitor tool" protocol=teensy tool="teensy:teensy-monitor"
2024-06-24T08:27:53.833Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded platform" platform="teensy:avr@1.58.1"
time="2024-06-24T04:27:53-04:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
time="2024-06-24T04:27:53-04:00" level=info msg="Loading tools from dir: C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\tools"
2024-06-24T08:27:53.834Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="teensy:teensy-compile@11.3.1"
2024-06-24T08:27:53.834Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Loaded tool" tool="teensy:teensy-tools@1.58.0"
2024-06-24T08:27:53.838Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2024-06-24T08:27:53.839Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\libraries" location=platform
2024-06-24T08:27:53.842Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.58.1\\libraries" location=platform
2024-06-24T08:27:53.844Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.11\\libraries" location=platform
2024-06-24T08:27:53.847Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.6.0\\libraries" location=platform
2024-06-24T08:27:53.849Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\digistump\\hardware\\avr\\1.6.7\\libraries" location=platform
2024-06-24T08:27:53.852Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.0.2\\libraries" location=platform
2024-06-24T08:27:53.855Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" location=platform
2024-06-24T08:27:53.857Z daemon INFO time="2024-06-24T04:27:53-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.0.4\\libraries" location=platform
time="2024-06-24T04:27:53-04:00" level=info msg="Loading libraries index file" index="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\library_index.json"
2024-06-24T08:27:54.019Z daemon INFO time="2024-06-24T04:27:54-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\AppData\\Local\\Arduino15\\libraries" location=ide
2024-06-24T08:27:54.020Z daemon INFO time="2024-06-24T04:27:54-04:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Hank\\Documents\\Arduino\\libraries" location=user
2024-06-24T08:27:54.846Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2024-06-24T08:27:54.846Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622877
    at E.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622893)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    at async a.<anonymous> (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:622563)
Hi @hankr.
This error indicates that something is wrong with the installation of the "Teensy" boards platform on your computer.
Other users who experienced this problem reported that it was fixed after uninstalling and then reinstalling the platform. Normally we can use the convenient Boards Manager GUI to uninstall platforms, but since the IDE doesn't start it will instead be necessary to uninstall it manually. After that, the IDE should start up and you can use Boards Manager to reinstall the platform.
I'll provide instructions you can follow to do that:
A. Uninstall "Teensy" Platform
  1. Close the Arduino IDE window if it is running.
  2. Delete the folder at the following path:
    C:\Users\Hank\AppData\Local\Arduino15\packages\teensy\
    :warning: Please be very careful when deleting things from your computer. When in doubt, back up!
    :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
The IDE should start successfully this time.
B. Reinstall "Teensy" Platform
The instructions above uninstalled the "Teensy" boards platform. If you need that platform, you should now reinstall it by following the official instructions here:
https://www.pjrc.com/arduino-ide-2-0-0-teensy-support/
Hopefully that will produce a fully working installation that won't interfere with the IDE's ability to start up on future sessions.
Please let me know if you have any questions or problems while following those instructions.
