It might work if you update your Arduino IDE to the latest version
And also don't forget to install the latest library for NRF24L01 tracnceiver
If it did compile and it still didn't work
The problem must be with your Hardware.
I cant seem to upload it, it get this error code
Arduino: 1.8.1 (Windows 10), Board: "Arduino Nano, ATmega328"
sketch_jan14b:71: error: expected initializer before 'Order'
void receive Order()
exit status 1
This is the code im trying to upload
#include <SPI.h>
#include <Servo.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
Servo myservo;
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Default Values
int servoPos = 92; // Steady point of the servo
void setup(void)
// Setup and configure rf radio
radio.begin();
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,15);
// optionally, reduce the payload size. seems to
// improve reliability
radio.setPayloadSize(8);
// Open pipes to other nodes for communication
// This simple sketch opens two pipes for these two nodes to communicate
// back and forth.
// Open 'our' pipe for writing
// Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
radio.openWritingPipe(pipes[1]);
radio.openReadingPipe(1,pipes[0]);
// Start listening
radio.startListening();
// Dump the configuration of the rf unit for debugging
// The servo is attached to pin 2
myservo.attach(2);
// Start with the steady point of the servo
myservo.write(servoPos);
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
unsigned long message;
bool done = false;
while (!done)
// Fetch the payload, and see if this was the last one.
done = radio.read( &message, sizeof(unsigned long) );
// Use it
// The servo can only ake a value fro 0 to 180
if(message > 180) message = 180;
else if(message < 0) message = 0;
// Save the postion
servoPos = message;
// Write the position to the servo
