arduino 2.4ghz camera reciver with 3g module
hello,
i want to start project to build arduino 2.4ghz camera reciver with 3g
so i want to know before began if it could work
the idea is to reciver (ISM 2,400MHz~ 2,483MHz CH1 CH3) from the camera and receive it on the 2.4 ghz module them use the net from the 3g sim or the GPRS to send the captured photo to email address
so it would work ? and if yes i would start to buy the parts with your guidance
What sort of 2.4GHz module did you have in mind? The ones I've seen have all been composite video.
AWOL: What sort of 2.4GHz module did you have in mind? The ones I've seen have all been composite video.
realy i dont know for the 3g module this on is good http://www.cooking-hacks.com/index.php/shop/arduino/wireless/3g-gprs-shield-for-arduino-3g-gps.html
but like i told i need one that can receive video from (ISM 2,400MHz~ 2,483MHz CH1 CH3 if u have good one show me it so the main ideal here it will work or not
Work out the data rate you need to transfer. This will depend on video resolution and frame rate. I would think your only chance is with an Arduino Due, the others are not fast enough.
Grumpy_Mike: Work out the data rate you need to transfer. This will depend on video resolution and frame rate. I would think your only chance is with an Arduino Due, the others are not fast enough.
but i want just to receive the video and take pictures from it , the cam is 30fps and not that mp , maby 2 its only 2mb so uno will be good for this ? and the project could be done ?
Can we get some specs here please? "The camera" is what? A composite video camera, sending composite video via a 2.4GHz link, and delivering a composite analogue video signal to a...what?
AWOL: Can we get some specs here please? "The camera" is what? A composite video camera, sending composite video via a 2.4GHz link, and delivering a composite analogue video signal to a...what?
Transmission Frequency ISM 2,400MHz~ 2,483MHz CH1 CH3
Audio subcarrier frequency 6.0Mhz
Antenna Built-in 2.4G antenna
Transmitting Range 300 feet in line of sight
CMOS Total Pixels 656 x 492(NTSC)
Horizontal resolution 420TV line
Frame rate 30FPS
Built-in mic.
55dB high sensitivity
View Angle 62
Camera lens focus Beyond:3m vicinity:10cm
Minimum Illumination 0.1 Lux / F1.5
Transmission Power 10mW
Operating voltage DC 5V
Operating current 105MA
So Friend :D wating ur reply
Awaiting your answer. (The question is: what is digitizing your signal?)
Hope you've got a big battery. ;)
No a Uno is not good for this. It runs at 16MHz so there is no way it can ship data at 2M. There is no JUST in what you want to do, it is serious processing of data.
AWOL:
1- when the reciever recieve it , it wont digitize it ? and i have not much knowledg :)
2- i just want to run it for 10 minutes
Grumpy_Mike:
ok ,if i brought the Due , could i connect all these components together so be able to do the project ? bcz me knowledge in Elc is not that much :sweat_smile:
If your knowlage is not that much then no you can not do this project. Is is not just a matter of connecting things up, it would be cutting edge, on the limit sort of stuff. If it is possible at all.
Grumpy_Mike:
but tell me it could be done ? and if i want some one trusted to do it can i find , or can u do it ? and i pays ?
OK, I'll save you some money, and tell you you're in the wrong forum. Analogue video capture is not suited to just about any flavour of Arduino.
Maybe if you told us what you want to do, not how you think it should be done, better help cold be offered.
AWOL: OK, I'll save you some money, and tell you you're in the wrong forum. Analogue video capture is not suited to just about any flavour of Arduino.
i want to do like that
first i want some way to put an 2.4ghz on the arduino to capture the video and takes photos from it(idk analog on digtal) but i want to get photos from the video after that install the 3g module and make it send the photos
Have you ever come across the expression "flogging a dead horse" this is what you are doing. The answer is No you can not do it. I am not sure if I can do it, but if I were to try you could not afford me.
Grumpy_Mike:
Have you ever come across the expression “flogging a dead horse” this is what you are doing.
ok thx any way , maby the house by wrong will win :wink:
I heard the smart money is on finding Elvis.
