Arduino, 2 Servos and PNA4602M IR Detector HELP
Guys Im trying to create an obstacle avoiding robot which uses 2 servos and a Panasonic PNA4602M IR Detector. Right now in my code I have a function which returns a 0 if it detects an object and a 1 if it does not detect anything. Based on those results I am telling the servos to go straight or make a turn. But I am not able to get the robot to make a turn. It just keeps going straight even with an obstacle in the way. Here is my code:
int servoPin6 = 6;          // Control pin for servo motor on Digital Pin 6
int servoPin7 = 7;          // Control pin for servo motor on Digital Pin 7
int pulse6 = 1019;          // Amount to pulse the servo on Pin 6
int pulse7 = 1607;          // Amount to pulse the servo on Pin 7
int irLedLeftPin = 10;      // IR Left Led on this pin
int irLedRightPin = 9;      // IR Right Led on this pin
int irSensorPin = 8;        // IR sensor on this pin
int func_return;
int irRead(int readPin, int triggerPin); //function prototype
  pinMode(servoPin6, OUTPUT);  // Set servo pin as an output pin
  pinMode(servoPin7, OUTPUT);  // Set servo pin as an output pin
  pinMode(irSensorPin, INPUT);
  pinMode(irLedLeftPin, OUTPUT);
     func_return = irRead(irSensorPin, irLedLeftPin);
      if (func_return = 1)
            Pulse(servoPin6, pulse6);       //Turn right wheel
            Pulse(servoPin7, pulse7);       //Turn left wheel
     else if (func_return = 0)
 * This function can be used with a panasonic pna4602m ir sensor
 * it returns a zero if something is detected by the sensor, and a 1 otherwise
 * The function bit bangs a 38.5khZ waveform to an IR led connected to the
 * triggerPin for 1 millisecond, and then reads the IR sensor pin to see if
 * the reflected IR has been detected
  int halfPeriod = 13; //one period at 38.5khZ is aproximately 26 microseconds
  int cycles = 38; //26 microseconds * 38 is more or less 1 millisecond
  int i;
  for (i=0; i <=cycles; i++)
    digitalWrite(triggerPin, HIGH);
    delayMicroseconds(halfPeriod);
    digitalWrite(triggerPin, LOW);
    delayMicroseconds(halfPeriod - 1);     // - 1 to make up for digitaWrite overhead
  return digitalRead(readPin);
 * This function is used to pulse the two servos
void Pulse(int servoPin, int servoPulse)
  digitalWrite(servoPin, HIGH);   // Turn the motor on
  delayMicroseconds(servoPulse);  // Length of the pulse sets the motor position
  digitalWrite(servoPin, LOW);    // Turn the motor off
  delayMicroseconds(19000);
Any help is greatly appreciated.
You have:
which should be:
if (func_return == 1)
and similarly in the other if statement.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Ahhh my bad, thanks alot sir. You saved my life!
