Arduino 2560 screen is only displaying white on screen
Hello!
I am working for a lab that recently purchased an Arduino 2560 board for the assembly of the LIQ HD (lickometer system) and it is only displaying a blank white screen. We have tried various things in order to make sure that the issue has nothing to do with the soldering including double checking all the solderings, making sure that we where following the instructions to build it and even did multiple multimeter tests from the prongs in the board to the actual full circuitry itself.
We have uploaded the code successfully onto the board, as it lets us know on the Arduino ide 2.3.5 that it has been uploaded successfully and the screen even changes in brightness when doing so. Any help or feedback would be appreciated!
No sketch, let alone one properly formatted with the <CODE/> tag.
No mention of the mystery shield that's between the Mega and the display.
No mention of which display you're using, let alone any links to technical data about it.
No mention of having tried the display alone with the Mega and some of the example programs from the library you're using.
No mention of which library you're using.
Hot glue???
Sorry for not providing enough information, I hope the information following that I will provide will be enough.
-Bellow is going to be an example of one of the libraries that we are using.
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <Wire.h>
#include <SD.h>
#include "RTClib.h"
#include "Adafruit_MPR121.h"
#include <Adafruit_ILI9341.h>
#include <Adafruit_FT6206.h>
#include <math.h>
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSans18pt7b.h>
#include <Fonts/FreeSansBold9pt7b.h>
#include <Fonts/FreeSansBold12pt7b.h>
#include <Fonts/FreeSansBold18pt7b.h>
#include <Fonts/FreeSansBold24pt7b.h>
//#define DEBUG //uncomment to turn on debug mode, prints info to Serial Monitor
#ifdef DEBUG
#define DEBUG_PRINT(x) Serial.print(x)
#define DEBUG_PRINTDEC(x) Serial.print(x, DEC)
#define DEBUG_PRINTLN(x) Serial.println(x)
#else
#endif
// The FT6206 uses hardware I2C on the shield
Adafruit_FT6206 ts = Adafruit_FT6206();
// The display also uses hardware SPI, plus #9 & #10
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
RTC_PCF8523 rtc; // define the Real Time Clock object
const int chipSelect = 7; // for the data logging shield, changed from digital pin 10
#define redLEDpin 13
DateTime now;
//capacitive touch device
#ifndef _BV
#define _BV(bit) (1 << (bit))
#endif
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
Adafruit_MPR121 cap2 = Adafruit_MPR121();
Adafruit_MPR121 cap3 = Adafruit_MPR121();
// Keeps track of the last pins touched so we know when buttons are 'released'
uint16_t lasttouched1 = 0;
uint16_t currtouched1 = 0;
uint16_t lasttouched2 = 0;
uint16_t currtouched2 = 0;
uint16_t lasttouched3 = 0;
uint16_t currtouched3 = 0;
File logfile; // the logging file
char filename[] = "00000000.CSV";
TS_Point p;
extern uint8_t welcome_logo[];
extern uint8_t main_logo[];
extern uint8_t settings_icon[];
extern uint8_t settings_icon2[];
unsigned long startmillis;
String E_side = "RIGHT";
String display_page = "main";
bool show_time = true;
bool eject_button;
int LOG_COUNTER;
int SYNC_COUNTER;
unsigned long currentMillis;
unsigned long previousMillis;
int syncTime;
int min_now;
int prev_min;
int curr_min;
int hour_now;
bool refresh_page = true;
int timeouts = 0;
bool ok;
int default_lights_on;
int default_lights_off;
int default_touch_threshold;
int default_release_threshold;
int default_LOG_INTERVAL;
int dafault_SYNC_INTERVAL;
bool default_auto_cal;
int default_auto_cal_time;
int default_auto_cal_sec_since_last_lick;
bool auto_cal_flag = true;
unsigned long cal_timer;
String logging[8];
bool log_LN = true;
bool log_LD = true;
bool log_BN = true;
bool log_BD = true;
bool log_BLN = true;
bool log_BLD = true;
bool recording = false;
String licked_bottle;
//enough for 18 cages, 2 lickometers per cage
unsigned long LickDuration[36];
unsigned long LickNumber[36];
unsigned long BoutNumber[36];
unsigned long BoutDuration[36];
unsigned long BoutLickNumber[36];
unsigned long BoutLickDuration[36];
unsigned long BoutLickDuration_bytime[36];
float LickFrequency[36];
float ILI[36];
unsigned long Elapsedtime[36];
unsigned long total_LN[36];
int lick_bout_countdown[36];
unsigned long bout_timer[36];
unsigned long bout_start_timer[36];
bool in_bout[36];
bool licking[36];
unsigned long time_now[36];
unsigned long last_lick_time[36];
// how many minutes between grabbing data and logging it.
int LOG_INTERVAL = 1; // IN MINUTES! between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
int SYNC_INTERVAL = 10; // IN MINUTES! between calls to flush() - to write data to the card
unsigned long emergency_counter = 60050; //1 minute +50ms
// Typically touch threshold > release threshold for debouncing
// Decrease value to increase sensitivity
int touch_threshold = 2; //default = 12
int release_threshold = 0; //default = 6
//int current = 50; //Range of 1-63uA //ignore for now
int debounce = 0; //range 0-7
bool auto_cal = true; //flag to turn on daily auto calibration by defaults
int auto_cal_time = 7; //hour in the day when auto cal will occur (best in light cycle when animals less active)
int auto_cal_sec_since_last_lick = 60; //Time in seconds of inactivity before auto cal will happen
int bout_cutoff = 3000; //bout cut off time in milliseconds
bool log_by_bout = false; //flag to turn on "log by bout" mode by default, ONLY ONE SHOULD BE TRUE
bool log_by_time = true; //flag to turn on "log by time" mode by default, ONLY ONE SHOULD BE TRUE
int lights_on = 6; //time of day (24hr time) housing lights turn ON
int lights_off = 18; //time of day (24hr time) houseing lights turn OFF
#ifdef DEBUG
#endif
pinMode(5, OUTPUT); // set screen brightness pin as output
analogWrite(5, 255);
set_defaults(); //save coded settings as the default settings
start_display(); //initialize display
start_rtc(); //iniitialize rtc
WelcomeScreen(); //display welcome screen at startup
set_brightness(); //set screen brightness depending on light cycle
main_menu_page();
recording_page();
pause_page();
SD_error_page();
settings_page();
error_page();
--https://www.youtube.com/watch?v=GOmjNMFOfgc. Yes. Hot glue.
does not seem to have a problem! not sure why though....
but I'm not an expert coder... could be a small problem...
Do you have the data logger shield and display wired to use the ICSP header for the hardware SPI? The SPI on the mega is not on pins 11/12/13.
