Arduino 2560 with Bluetooth device
Hello everyone :slight_smile: I am a new guy here, wanna ask a question which puzzle me for a few days…
I want to use Bluetooth device http://goods.ruten.com.tw/item/show?21204206581641
(baud 57600, Input_Voltage is 3.6V~6V, Frequency)
on my Arduino 2560 and receive data,but it did not work
Here is how I connect:
BT_device <-> arduino
VCC <-> 5V
GND <-> GND
TX <-> RX1(or 2 , 3)
RX <-> TX1
The BT device did successfully connected, but it only receive “224” when I send other numbers(recive"0"or"-1"when not sending)
I have checked with PC BT_device that the message I send is correct
Is my BT device broken(that is new :P),or I missed something?
=====Here is my code=====
#include <SoftwareSerial.h>
int BTread;
Serial.begin(57600);
Serial1.begin(57600);
BTread =Serial1.read();
Serial.println(BTread);
You have 4 hardware serial ports. You connect the bluetooth device to one of them. So, why are you including this header file?
Reading data that may not have arrived, and then printing it, is not a good idea. There IS an available() method in the HardwareSerial class.
If you use that method, the data that read() method returns will fit in a char, instead of an int. I suspect that you’ll be a lot happier if you can use a char, instead.
Dear PaulS:
Thanks for you rapid reply :slight_smile:
I am sorry that the problem still exist. The monitor keep showing blank(nothing) and à when I change int to char.
Is there hardware or software problem :astonished:?
Thanks again
Jay
Here is my modified code:
char BTread;
 if (Serial1.available() > 0)
 Serial.println("");
The attach file is the monitor screen
