@nico78
oui mais .... RemoteXY sait déjà gérer le module BLE intégré à l'ESP32, (testé)
En étudiant la librairie fournie et en transposant à la librairie BLE des Nano 33 BLE il reste de l'espoir...
Avec le code que tu as posté plus haut au message #8 (nano 33 BLE en émulation HM-10) la compatibilité de RemoteXY avec les cartes nano 33 BLE n'est peut être pas éloignée !!
Dernière version de la libaririe RemoteXY :
Configuration :
Avoir les fichiers .h joints où l'ESP32 émule un HM-10
Voici le sketch de test qui tourne sur ESP32 avec son BLE interne
RemoteXY example.
Smartphone connect via BLE on ESP32.
This shows an example of using the library RemoteXY.
In the example you can control the LED pin 2 using the button on the
smartphone. The example uses the BluetoothSerial library which is a standard
library in the Arduino IDE on ESP32.
Download the mobile app from the
website: http://remotexy.com/download/ for connect this sketch.
Use the website http://remotexy.com/ to create your own management
interface your arduino with your smartphone or tablet.
You can create different management interfaces. Use buttons,
switches, sliders, joysticks (g-sensor) all colors and sizes
in its interface. Next, you will be able to get the sample
code for arduino to use your interface for control from a
smartphone or tablet. You will not need to re-install the
android app, as it will determine which interface you have
downloaded the arduino.
// RemoteXY include library //
//#define REMOTEXY__DEBUGLOGS Serial
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__ESP32_BLE
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_BT_DEVICENAME "RemoteXY32"
// RemoteXY configurate
//unsigned char RemoteXY_CONF[] =
// { 1,0,11,0,1,5,1,0,21,2
// ,59,59,2,88,0 };
// ci dessous l'interface graphique
uint8_t RemoteXY_CONF[] =
{ 255,2,0,1,0,36,0,10,13,0,
2,0,34,8,30,17,2,26,31,31,
79,78,0,79,70,70,0,66,131,27,
36,45,19,2,24,4,0,84,8,12,
49,2,26 };
// this structure defines all the variables of your control interface
struct {
// input variable
//unsigned char button_1; // =1 if button pressed, else =0
uint8_t switch_1; // =1 if switch ON and =0 if OFF
int8_t slider_1; // =0..100 slider position
// other variable
unsigned char connect_flag; // =1 if wire connected, else =0
} RemoteXY;
// END RemoteXY include //
#define LED_BUILTIN 22
RemoteXY_Init ();
pinMode (LED_BUILTIN, OUTPUT);
RemoteXY_Handler ();
digitalWrite(LED_BUILTIN, (RemoteXY.switch_1==0)?LOW:HIGH);
RemoteXY_ESP32_BLE.ino (2.31 KB)
RemoteXYStream_BLEDevice.h (4.67 KB)
RemoteXYStream_BluetoothSerial.h (893 Bytes)
