#define PZT_PIN_1 A0
#define PZT_PIN_2 A1
#define PZT_PIN_3 A2
#define PZT_PIN_4 A3
#define PZT_PIN_5 A4
#define PZT_PIN_6 A5
#define IMPACT_THRESHOLD 5
int sensor_values[6];
int previous_values[6] = {0, 0, 0, 0, 0, 0};
volatile int total_samples = 0; // 'volatile' ensures the variable can be updated from an interrupt
volatile bool adcFlag = false; // Flag to indicate an ADC sample is ready
volatile uint32_t sampleCounter = 0; // Counter for the number of samples taken
Serial.begin(115200); // Changed baud rate to 115200
while (!Serial);
pinMode(PZT_PIN_1, INPUT);
pinMode(PZT_PIN_2, INPUT);
pinMode(PZT_PIN_3, INPUT);
pinMode(PZT_PIN_4, INPUT);
pinMode(PZT_PIN_5, INPUT);
pinMode(PZT_PIN_6, INPUT);
// Enable interrupt for the custom SAADC handler
NVIC_SetPriority(SAADC_IRQn, 1UL);
NVIC_EnableIRQ(SAADC_IRQn);
// Read sensor values
sensor_values[0] = analogRead(PZT_PIN_1);
sensor_values[1] = analogRead(PZT_PIN_2);
sensor_values[2] = analogRead(PZT_PIN_3);
sensor_values[3] = analogRead(PZT_PIN_4);
sensor_values[4] = analogRead(PZT_PIN_5);
sensor_values[5] = analogRead(PZT_PIN_6);
int change[6];
for (int i = 0; i < 6; i++) {
change[i] = sensor_values[i] - previous_values[i];
bool impact_detected = false;
if (abs(change[i]) > IMPACT_THRESHOLD) {
impact_detected = true;
if (impact_detected) {
total_samples++;
Serial.print(total_samples);
Serial.print("\t");
Serial.print(change[i]);
if (i < 5) Serial.print("\t");
// Update previous values
previous_values[i] = sensor_values[i];
// Renamed interrupt handler to avoid conflict
extern "C" void custom_SAADC_IRQHandler(void) {
if (NRF_SAADC->EVENTS_END != 0) {
NRF_SAADC->EVENTS_END = 0;
adcFlag = true; // Set the flag when a sample is ready
sampleCounter++; // Increment the sample counter
THis is my code it read data from PZT sensor. I want to increase the sampling frequency. I tried more method but those are not working. im using arduino 33 ble.
