Arduino 3G/GPS (SMS)
Hi everybody.
I need some help with my project. I'm using Arduino UNO with 3G/GPS shield. I'm trying to receive SMS with character. It's arduino shield's events or functions.
The code works just like that:
First, I send a SMS from my mobile device to Arduino 3G/GPS shield. Then Arduino receives and reads it. If the SMS's body is a "1", arduino does the function associated to "1". The SMS with "2"....activate the function "2". And so on.
In short, I need a code that is waiting for an SMS ("1", "2" ...) and likewise perform a particular function, whether I get the GPS location, or capture pictures with the camera shield 3G / GPS.
Thanks a lot. I hope you understand me.
Here I insert the main code and its functions.
Main code:
int8_t answer, counter;
char salir;
int x;
int onModulePin= 2;  // Pin para activar o desactivar el módulo 3G
char aux_string[30];
char response[255];
char SMS[200];
int a=0;
int y=0;
int z=0;
char phone_number[]="3214435420";
//int b= 0;
char name[20];
char picture_name[20];
//GPS
char gps_data[100];
int contador;
char data[255];
char latitude[12],longitude[13];
char date[7],UTC_time[9];
char speed_OG[7],altitude[7];
void(*Reset)(void)=0;
void setup(){
    pinMode(13, OUTPUT);
    pinMode(onModulePin, OUTPUT);  // Pin para activar modulo como salida
    Serial.begin(115200);     //Configuramos puerto UART
    Serial.println("Starting..."); //Activamos el módulo 3G
    power_on();
    delay(3000);
    //Configuramos SD como espacio de almacenamiento principal.
    sendATcommand("AT+FSLOCA=1","OK",2000);
    Serial.println("Setting SD storage...");
    Serial.println("AT+CNSM=1"); // Enables noise supression
    while(Serial.read()!='K');
    Serial.println("Setting SMS mode...");
    sendATcommand("AT+CMGF=1", "OK", 1000);    // Configuramos el SMS a modo texto
   //  Serial.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
    sendATcommand("AT+CPMS=\"SM\",\"SM\",\"SM\"", "OK", 1000);    // selects the memory
   //delay(5000);
   //answer = sendATcommand("AT+CMGD=1,4", "+CMGD:", 2000);
   //Serial.println("AT+CMGD=1,4"); // delete all SMS
Serial.println("Send your SMS, 20 sec remaining...");
    delay(20000);
   //answer = sendATcommand("AT+CMGRD=1", "+CMGRD:", 2000);
   answer = sendATcommand("AT+CMGR=1", "+CMGR:", 2000);    // Se lee el primer SMS en la sim card
    if (answer == 1)
        answer = 0;
        while(Serial.available() == 0);
        // Este buble lee los datos del SMS, lo q llega del SMS
        do{
            // Si hay datos en el buffer de entrada UART, lo lee y comprueba la answer(respuesta)
            if(Serial.available() > 0){
                SMS[x] = Serial.read();
                    if (SMS[x] == '5')
                      Serial.println("Voice");
                      rec_voz();
                      delay(2000);
                      Reset();
                    else if (SMS[x] == '4')
                      Serial.println("Alarm");
                      Alarma();
                      delay(2000);
                      Reset();
                    else if (SMS[x] == '2')
                      Serial.println("Taking pic!");
                      tomaFoto();
                      delay(2000);
                      Reset();
                    else if (SMS[x] == '1')
                      Serial.println("Getting GPS position...");
                    get_GPS();
                    delay(2000);
                    Reset();
                x++;
                // Se comprueba si la respuesta deseada (OK) es en la respuesta del módulo
                if (strstr(SMS, "OK") != NULL)
                    answer = 1;
        while(answer == 0);    // Espera por la respuesta (answer) con el tiempo de espera
        SMS[x] = '\0';
      //  Serial.print(SMS);    // Se imprime el valor de SMS     -->Serial.print(val)
        Serial.print("error "); // se imprime error
        //imprime como codificado ASCII decimal
        Serial.println(answer, DEC); //Serial.print(val, format) -> format: especifica el número de la base (para números enteros) o el número de posiciones decimales (para números de coma flotante o tipo "float")
    // Serial.println("AT+CFUN=1,1"); //reset shield
//sendATcommand("AT+CMGD=1,4", "+CMGD:", 2000);
//delay(2000);
sendATcommand("AT+CFUN=1,1","+CFUN:",2000);
Reset();
void loop(){
void power_on(){
    uint8_t answer=0;
    // / / Comprueba si el módulo es iniciado
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // Espera por una respuesta(answer) del módulo
        while(answer == 0){     // Enviar AT cada dos segundos y esperar la  (answer)
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Inicializa la cadena (string)
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Limpiar el buffer de entrada
    Serial.println(ATcommand);    // Enviar el comando AT
        x = 0;
    previous = millis();
    // Este bucle espera por la respuesta (answer)
    do{
        // Si hay datos en el buffer de entrada UART, lo lee y comprueba la asnwer
        if(Serial.available() != 0){
            response[x] = Serial.read();
            x++;
            // comprobar si la respuesta deseada es en la respuesta del módulo
            if (strstr(response, expected_answer) != NULL)
                answer = 1;
        // Waits for the asnwer with time out
    }while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1, char* expected_answer2,
    char response[100];
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
    x = 0;
    // this loop waits for the answer
    do{
        // if there are data in the UART input buffer, reads it and checks for the asnwer
            x++;
            // check if the desired answer 1 is in the response of the module
            if (strstr(response, expected_answer1) != NULL)
                answer = 1;
            // check if the desired answer 2 is in the response of the module
            if (strstr(response, expected_answer2) != NULL)
                answer = 2;
    return answer;
Alarm function:
void Alarma(){
     if(SMS[x] == '4')
     Serial.println("AT+FSCD=D:/Audio");                //Indicamos en que carpeta esta nuestro mp3
     Serial.println("carpeta configurada");
     Serial.println("AT+CSDVC=3");                      //Le decimos por donde queremos que lo reproduzca, el 3 para el speaker, el 2 para conectar los audífonos.
     Serial.println("altavoz seleccionado");
     Serial.println("AT+CCMXPLAY=\"alarma.MP3\",0");    //Le damos al play
     Serial.println("reproduciendo");
     //retorna a rutina main.
Cam function:
 Secuencias para la toma de fotografias
 desde el modulo 3G
//Configuramos parámetros cámara
void tomaFoto(){
  if (SMS[x] == '2')
  Serial.println("Haciendo fotografia...");
  Serial.println("AT+CCAMS");                    //Iniciamos la camara
  Serial.println("AT+CCAMSETD=640,480");         //Indicamos la resolucion
  Serial.println("AT+CCAMTP");                   //Tomamos la fotografia
  delay(2000);
  Serial.println("AT+CCAMEP");                   //Guardamos la foto
  Serial.flush();
  while(Serial.read()!='/');                     //Seleccionamos a partir de donde vamos a empezar a guardar el nombre de la foto
  //Guardamos el nombre de la foto para luego enviarla
  int z=0;
  //Mientras z sea menor que 19...
  do
     while(Serial.available()==0);               //Mientras no haya nada en el puerto serie..funciona en standby..
     name[z]=Serial.read();                      //A partir de que reciba algo, lo empieza a almacenar
     z++;
  while(z < 19);
    Serial.print("El nombre de la foto es ");
    Serial.println(name);
    Serial.println("AT+CCAME");                  //Se detiene la cam
    Serial.println("Foto almacenada correctamente...");
GPS function:
void get_GPS(){
   answer = sendATcommand("AT+CGPS=1,1","OK",1000);
    if (answer == 0)
        Serial.println("Error starting the GPS");
        Serial.println("The code stucks here!!");
        while(1);
  if (SMS[x] == '1')
    answer = sendATcommand("AT+CGPSINFO","+CGPSINFO:",1000);
 delay(60000);   // request info from GPS
    if (answer == 1)
        contador = 0;
        do{
            gps_data[contador] = Serial.read();
            contador++;
        while(gps_data[contador - 1] != '\r');
        gps_data[contador] = '\0';
        if(gps_data[0] == ',')
             Serial.println("No GPS data available");
            Serial.print("GPS data:");
            Serial.println(gps_data);
            Serial.println("");
        Serial.println("Error");
    delay(2000);  //en caso de if
Recording voice function:
void rec_voz()
  if (SMS[x] == '5')
  //RECORDING A SOUND CLIP
int onModulePin = 2;
char clip_name[20];
char aux_str[50];
    // Takes a picture, but not saved it
    answer = sendATcommand2("AT+CQCPREC=0,amr", "D:/Audio/", "ERROR", 5000);
    if (answer == 1)
        counter = 0;
        do{
            clip_name[counter] = Serial.read();
            counter++;
        while (clip_name[counter-1] != 0x0D);
        clip_name[counter-1] = '\0';
        Serial.print("Clip name: ");
        Serial.println(clip_name);
        delay(10000);
        sendATcommand2("AT+CQCPPAUSE", "OK", "ERROR", 2000);
        delay(5000);
        sendATcommand2("AT+CQCPRESUME", "OK", "ERROR", 2000);
        delay(5000);
        sendATcommand2("AT+CQCPSTOP", "OK", "ERROR", 2000);
        sendATcommand2("AT+FSCD=D:/Audio", "OK", "ERROR", 2000);
        sprintf(aux_str, "AT+CCMXPLAY=\"%s\",0", clip_name);
        answer = sendATcommand2(aux_str, "OK", "ERROR", 2000);
        if (answer == 1)
            delay(5000);
            sendATcommand2("AT+CCMXPAUSE", "OK", "ERROR", 2000);
            delay(5000);
            sendATcommand2("AT+CCMXRESUME", "OK", "ERROR", 2000);
            delay(10000);
            sendATcommand2("AT+CCMXSTOP", "OK", "ERROR", 2000);
            Serial.println("Error playing");
        Serial.println("Error recording");
