Arduino 433mhz RF simple led on and off HELP!
hello guys i need your help how can i simply turn on an led to other arduino
like this:
if(message == "1"){
digitalWrite(LED, HIGH);
} else{
digitalWrite(LED, LOW)
but i have a problem i done this with the use of bluetooth module HC-06 / 05 but when i use 433mhz rf i dont know how to send and receive data :( does someone know how to send a simple message to turn on an led :( thanks
The VirtualWire library (now obsolete, but it still works) has examples of sending and receiving messages. What you do with the message is up to you.
yup :) i tried using the virtual wire examples. but its so confusing i dont even understand how the receiver decode the message. thanks
That's the great part about using a library. You do not need to understand how it does it's magic.
What you get is a return code that says whether or not the library got any data, and, if it did, a length and a buffer with the data in it.
The buffer CAN be a char array. The length tells you where to put the NULL to make a string of the char array.
Then, strcmp() can compare the buffer to known commands, like "LedOn" or "TakeAHike".
