arduino 60 second countdown and count up timer.
i have 2 inputs. Im looking for a code that will have me activate my two 7-segment display counting up , whenever i activate an input, and count down when i press the other. can anybody help? . i badly need it. my knowledge is not yet enough to code this kind of program. please help me. any help would do. thank you . :) If anyone could provide me the code. Id be so much fascinated (Y)
I'd start with reading this very good guide:
guide
Then reading up on the 7seg Arduino page:
7 seg
thank you so much :)
Part 1
int pin1 = 2;
int pin2 = 3;                                    //                            --6--
int pin3 = 4;                                    //                         5 |     | 7
int pin4 = 5;                                    //                           |--4--|
int pin5 = 6;                                    //                         1 |     | 3
int pin6 = 7;                                    //                            --2--
int pin7 = 8;
int gnd1 = 11;                                  //                          gnd1 is display 1's gnd
int gnd2 = 9;                                   //                          gnd2 is display 2's gnd
int timer = 500;                               //   A timer, to run the for loop 500 times, which turns out as 1 second.
int value;                                        //   The value, part of the FADING display
void setup(){
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT);
  pinMode(pin3, OUTPUT);
  pinMode(pin4, OUTPUT);           //The following sets up all of the pins for use.
  pinMode(pin5, OUTPUT);
  pinMode(pin6, OUTPUT);
  pinMode(pin7, OUTPUT);
  pinMode(gnd1, OUTPUT);
  pinMode(gnd2, OUTPUT);
  for (int i=0; i<timer; i++){                     //   The for loop, for running the program 500 times.
   digitalWrite(pin1, B1);
   digitalWrite(pin2, B1);
   digitalWrite(pin3, B0);
   digitalWrite(pin4, B1);
   digitalWrite(pin5, B0);
   digitalWrite(pin6, B1);
   digitalWrite(pin7, B1);
   digitalWrite(gnd1, B0);
   digitalWrite(gnd2, B1);
   delay(0.5);                                        //          Writes 20 to the display.
   digitalWrite(pin3, B1);
   digitalWrite(pin4, B0);
   digitalWrite(pin5, B1);
   digitalWrite(gnd1, B1);
   digitalWrite(gnd2, B0);
   delay(0.5);
   digitalWrite(pin1, B0);
   digitalWrite(pin2, B0);
   digitalWrite(pin6, B0);
   delay(0.5);                                        //          Writes 19 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 18 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 17 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 16 to the display.
   digitalWrite(pin7, B0);
   delay(0.5);
   delay(0.5);                                        //          Writes 15 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 14 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 13 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 12 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 11 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 10 to the display.
   delay(0.5);
Part 2
   delay(0.5);                                        //          Writes 09 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 08 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 07 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 06 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 05 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 04 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 03 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 02 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 01 to the display.
   delay(0.5);
   delay(0.5);                                        //          Writes 00 to the display.
   delay(0.5);
  digitalWrite(13, HIGH);   //  Turns the TIMER ENDED LED on.
   for(value = 0 ; value <= 255; value+=5) // fade in (from min to max)
    analogWrite(gnd1, value);           // sets the value (range from 0 to 255)
    analogWrite(gnd2, value);           // sets the value (range from 0 to 255)
    delay(10);                            // waits for 30 milli seconds to see the dimming effect
  for(value = 255; value >=0; value-=5)   // fade out (from max to min)
    delay(10);
hopefully this will help you along your way, Give you an idea of where you need to go.
Treat yourself, use some arrays to hold all your digit representations and pin numbers.
@tammytam. okay sir. thank you so much.
@mathewbuer . thanks sir. awesome. thank you.
One of my early 'learning' sketches was to implement a count down timer similar to what you have described, so you may get some ideas from there. The time value was set by a pot, not buttons. You can find the code in my code library site - link in my signature below.
