Finalmente sono disponibil anche a noi poracci i nuovi PICCONI (chiamo così i grossi PIC) della serie MZ. Roba da 200 MHz, con 2048 KB di Flash (vi bastano?) 512 KB di RAM, DSP engine e una serie di periferiche da fantascienza.
Il bootloader è già stato scritto, il PICCONE l'ho ordinato da TME... devo solo montarlo su un adattatore e cominciare con qualche blink a 200 MHz... ![]()
Siete pronti a far lampeggiare il vostro LED con 330 MILLIONI di istruzioni al secondo? ![]()
A breve qualche news su qualche esperimento serio... ![]()
Key Features
200 MHz/330 DMIPS, microAptiv core
DSP-enhanced core:
Four 64-bit accumulators
Single-cycle MAC, saturating and fractional math
Dual Panel Flash for live update support
10-bit, 500 KSPS, 48-channel ADC module
Memory Management Unit for optimum embedded OS execution
microMIPS mode for up to 35% code compression
CAN, UART, I2C, PMP, EBI, SQI & Analog Comparators
SPI/I2S interfaces for audio processing and playback
Hi-Speed USB 2.0 Device/Host/OTG
10/100 Mbps Ethernet MAC with MII and RMII interface
Temperature Range: - 40°C to 85°C; - 40°C to 125°C (planned)
Microcontroller Features
Operating voltage range of 2.2V to 3.6V
2MB Flash memory (plus an additional 160 KB of Boot Flash)
512KB SRAM memory
microMIPS mode for up to 35% smaller code size
DSP-enhanced core:
Single-cylce MAC, saturating and fractional math
Code-efficient (C and Assembly) architecture
Low-power management modes (Idle and Sleep)
Peripheral Features
50 MHz External Bus Interface (EBI)
50 MHz Serial Quad Interface (SQI)
Peripheral Pin Select (PPS) functionality to enable function remap
8 channels of hardware programmable DMA and 16 channels of dedicated DMA with automatic data size detection
Six UART modules (25 Mbps): Supports LIN 1.2 and IrDA protocols
Two CAN modules 2.0B Active with DeviceNet addressing support
Six 4-wire SPI modules (50 Mbps)
SQI configurable as an additional SPI module (50 MHz)
Five I2C modules (up to 1 Mbaud) with SMBus support
Parallel Master Port (PMP)
Hardware Real-Time Clock and Calendar (RTCC)
Nine 16-bit Timers/Counters (four 16-bit pairs combine to create four 32-bit timers)
Nine Capture inputs and Nine Compare/PWM outputs
Audio/Graphics/Touch HMI Features
Graphics interface: EBI or PMP
Audio data communication: I2S, LJ, RJ, USB
Audio data control interface: SPI and I2C™
Audio data master clock: Fractional clock frequencies with USB synchronization
Advanced Analog Features
10-bit ADC Module:
500 Ksps rate with one Sample and Hold (S&H) circuits
Up to 48 analog inputs
Flexible and independent ADC trigger sources
6 digital filters and comparators
Two analog comparators with 32 programmable voltage references
Temperature sensor with ±2°C accuracy
Debugger Development Support
In-circuit and in-application programming
4-wire MIPS® Enhanced JTAG interface
Unlimited program and 12 complex data breakpoints
IEEE 1149.2-compatible (JTAG) boundary scan
Non-intrusive hardware-based instruction trace
