Arduino A device attached to the system is not functioning.
I have arduino connected to usb with own power supply 3 x8 relays (24) 220V . Evry relay board (8) have their power supply, evrything works ok until i dont connect something to relay, i can turn on/off relay for as many times i want. After I connect something, lets say light bulb to the relay works for few times on/off but after that i get error in visual studio:
An exception of type 'System.IO.IOException' occurred in System.dll but was not handled in user code
Additional information: A device attached to the system is not functioning.
Its obviusly hardware error, but i dont know what, and how to solve it, thank you for your help.
And the code for asp.net / C#:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.IO.Ports;
namespace Smart_House
    public partial class WebForm1 : System.Web.UI.Page
        SerialPort serijska_vrata;
        protected void Page_Load(object sender, EventArgs e)
            Button3.Text = "\uf011";
            /*Inicializacija dropdownList*/
            DropDownList1.Items.Add("COM3");
            DropDownList1.Items.Add("COM2");
            DropDownList1.Items.Add("COM1");
            DropDownList1.Items.Add("COM4");
            DropDownList1.Items.Add("COM5");
            DropDownList1.Items.Add("COM6");
            DropDownList1.Items.Add("COM7");
            DropDownList1.Items.Add("COM8");
            DropDownList1.Items.Add("COM9");
            /*Inicializacija Serialport*/
            serijska_vrata = new SerialPort();
            serijska_vrata.PortName = DropDownList1.Text;
            serijska_vrata.BaudRate = 9600;
        protected void DropDownList1_SelectedIndexChanged(object sender, EventArgs e)
        protected void Button1_Click(object sender, EventArgs e)
        static bool on_off_namizna = false;
        protected void Button3_Click(object sender, EventArgs e)
            if (on_off_namizna == false)
                    serijska_vrata.Open();
                    serijska_vrata.Write("1");
                    button_style.Href = "Buttonon.css";
                    label_style.Href = "labelon.css";
                    on_off_namizna = true;
                    serijska_vrata.Close();
                    serijska_vrata.Dispose();
            else if (on_off_namizna == true)
                    serijska_vrata.Write("0");
                    button_style.Href = "Buttonoff.css";
                    label_style.Href = "labeloff.css";
hi. have you solve this problem? i have the same problem now.
