Arduino Accessory Mode library problem
Hellow All,
I have arduino mega adk. I'm trying to configure arduino sketch.
I downloaded library from http://labs.arduino.cc/uploads/ADK/GettingStarted/ArduinoADK-beta-001.zip
I use version1 in zip file.
i use following code for test
// accessory descriptor. It's how Arduino identifies itself to Android
char accessoryName[] = "Mega_ADK"; // your Arduino board
char companyName[] = "Arduino SA";
// led variables
int ledPin = 13;
// counters
long timer = millis();
// initialize the accessory:
AndroidAccessory usb(companyName, accessoryName);
  Serial.begin( 9600 );
  // start the connection to the device over the USB host:
  usb.begin();
  pinMode(ledPin, OUTPUT);
  /* Print to usb */
  if(millis()-timer>100) { // sending 10 times per second
    if (usb.isConnected()) { // isConnected makes sure the USB connection is ope
      char val = usb.read();
      Serial.print( val );
      if( val == 'a' )
        digitalWrite( ledPin, HIGH );
      else if( val == 'b' )
        digitalWrite( ledPin, LOW );
    timer = millis();
but it gives me following error. Is this library old new for the codes im using ? How can i find correct libraries ?
C:\Users\cihan\AppData\Local\Temp\cc9mMbFm.ltrans0.ltrans.o: In function `__static_initialization_and_destruction_0':
C:\Users\cihan\Documents\Arduino\sketch_feb02b/sketch_feb02b.ino:29: undefined reference to `AndroidAccessory::AndroidAccessory(char const*, char const*, char const*, char const*, char const*, char const*)'
C:\Users\cihan\AppData\Local\Temp\cc9mMbFm.ltrans0.ltrans.o: In function `setup':
C:\Users\cihan\Documents\Arduino\sketch_feb02b/sketch_feb02b.ino:34: undefined reference to `AndroidAccessory::begin()'
C:\Users\cihan\AppData\Local\Temp\cc9mMbFm.ltrans0.ltrans.o: In function `loop':
C:\Users\cihan\Documents\Arduino\sketch_feb02b/sketch_feb02b.ino:42: undefined reference to `AndroidAccessory::isConnected()'
C:\Users\cihan\Documents\Arduino\sketch_feb02b/sketch_feb02b.ino:43: undefined reference to `AndroidAccessory::read()'
collect2.exe: error: ld returned 1 exit status
exit status 1 Error compiling for board Arduino Mega ADK.
I’m pretty sure you left a line off the code you posted:
#include <AndroidAccessory.h>
Which version of the Arduino IDE are you using?
