Hi
Im having trouble uploading blink and any other sketch to my new Arduino/Adafruit board Micro
I'm Using:
Arduino IDE 1.0.2
Windows XP Pro
Windows driver for Micro "usbser.sys"
When i click upload the RX flashes once and then bootloader starts after the board resets,
in the meantime IDE finishes upload but the Micro is still running bootloader
RX on the board then flashes twice and nothing happens, the sketch doesn't load.
I've found what i think is the problem, the port is currently connected to USB port 14 but the
recconnection to port 14 fails after the Micro resets.
here is an excerpt from the upload screen
Binary sketch size: 4,816 bytes (of a 28,672 byte maximum)
Forcing reset using 1200bps open/close on port COM14
PORTS {COM1, COM14, } / {COM1, COM14, } => {}
PORTS {COM1, COM14, } / {COM1, } => {}
PORTS {COM1, } / {COM1, } => {}
PORTS {COM1, } / {COM1, COM13, } => {COM13, }
Found Leonardo upload port: COM13
E:\Apps\Arduino\arduino-1.0.2\hardware/tools/avr/bin/avrdude -CE:\Apps\Arduino\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P\\.\COM13 -b57600 -D -Uflash:w:C:\DOCUME~1\RENIER~1\LOCALS~1\Temp\build348112787411548573.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "E:\Apps\Arduino\arduino-1.0.2\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM13
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: ser_send(): write error: sorry no info avail
so i tried different USB ports and the same thing happened plugged the Micro into port 10
then I get a phantom Leonardo board pop up on port 9 and so on...
So I've updated the windows USB drivers, and I've tried the board on all the USB ports with no luck
Any advice or tricks on how to upload to the Arduino Micro?
Thanx!
