Arduino Adafruit project: Uno + Xively + CC3000 + digital lux sensor, error help
Hey all here is my situation
When i run the following code i get up to initializing the connection with xively, but afterwards i get an error message that reads:
400 Bad Request
400 Bad Request
nginx/1.1.19
I have tried many different things, but do keep in mind i have to modify the original project so that i could integrate my lux sensor instead. I am not sure what nginx means, and I keep getting that error over and over. Any help? Please find my code below
Please let me know if you have any ideas, i have just started with arduino today, and it's been a pain in the rear!!
  This is a sketch to use the CC3000 WiFi chip & Xively
  Written by Marco Schwartz for Open Home Automation
// Libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include "DHT.h"
#include<stdlib.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2561.h>
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Create CC3000 instances
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIV2); // you can change this clock speed
// WLAN parameters
#define WLAN_SSID       "myssid" //i edited out the real ones
#define WLAN_PASS       "password"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY   WLAN_SEC_WPA2
// Xively parameters
#define WEBSITE  "api.xively.com"
#define API_key  "12345" //i edited out the real one
#define feedID  "123456" //i edited out the real one
uint32_t ip;
Adafruit_TSL2561 tsl = Adafruit_TSL2561(TSL2561_ADDR_FLOAT, 12345);
    Displays some basic information on this sensor from the unified
    sensor API sensor_t type (see Adafruit_Sensor for more information)
void displaySensorDetails(void)
  sensor_t sensor;
  tsl.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" lux");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" lux");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" lux");
  Serial.println("");
    Configures the gain and integration time for the TSL2561
void configureSensor(void)
  /* You can also manually set the gain or enable auto-gain support */
  // tsl.setGain(TSL2561_GAIN_1X);      /* No gain ... use in bright light to avoid sensor saturation */
  // tsl.setGain(TSL2561_GAIN_16X);     /* 16x gain ... use in low light to boost sensitivity */
  tsl.enableAutoGain(true);          /* Auto-gain ... switches automatically between 1x and 16x */
  /* Changing the integration time gives you better sensor resolution (402ms = 16-bit data) */
  tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_13MS);      /* fast but low resolution */
  // tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_101MS);  /* medium resolution and speed   */
  // tsl.setIntegrationTime(TSL2561_INTEGRATIONTIME_402MS);  /* 16-bit data but slowest conversions */
  /* Update these values depending on what you've set above! */
  Serial.print  ("Gain:         "); Serial.println("Auto");
  Serial.print  ("Timing:       "); Serial.println("13 ms");
void setup(void)
  // Initialize
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
     /* Initialise the sensor */
  if(!tsl.begin())
    /* There was a problem detecting the ADXL345 ... check your connections */
    Serial.print("Ooops, no TSL2561 detected ... Check your wiring or I2C ADDR!");
    while(1);
  /* Display some basic information on this sensor */
  displaySensorDetails();
  /* Setup the sensor gain and integration time */
  configureSensor();
  /* We're ready to go! */
  Serial.println("");
void loop(void)
    int light = 0;
   sensors_event_t event;
  // Connect to WiFi network
  cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
  Serial.println(F("Connected!"));
  /* Wait for DHCP to complete */
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100);
  // Get the website IP & print it
  ip = 0;
  Serial.print(WEBSITE); Serial.print(F(" -> "));
  while (ip == 0) {
    if (! cc3000.getHostByName(WEBSITE, &ip)) {
      Serial.println(F("Couldn't resolve!"));
  cc3000.printIPdotsRev(ip);
  tsl.getEvent(&event);
  // Get data & transform to integers
 //uint16_t broadband = 0;
// uint16_t infrared = 0;
  light = event.light;
// getLuminosity (&broadband, &infrared);
  // Prepare JSON for Xively & get length
  int length = 0;
  String data = "";
  data = data + "\n" + "{\"version\":\"1.0.0\",\"datastreams\" : [ {\"id\" : \"Temperature\",\"current_value\" : \"" + String(light) + "\"},"
  + "{\"id\" : \"Humidity\",\"current_value\" : \"" + String(light) + "\"}]}";
  //data = data + "\n" + "{\"version\":\"1.0.0\",\"datastreams\" : [ {\"id\" : \"Temperature\",\"current_value\" : \"" + String(light) + "\"}]}""\"]},";
  length = data.length();
  Serial.print("Data length");
  Serial.println(length);
  // Print request for debug purposes
  Serial.print("PUT /v2/feeds/");
  Serial.print(feedID);
  Serial.println(".json HTTP/1.0");
  Serial.println("Host: http://www.api.xively.com");
  Serial.print("X-ApiKey: ");
  Serial.println(API_key);
  Serial.print("Content-Length: ");
  Serial.println(length, DEC);
  Serial.print("Connection: close");
  Serial.print(data);
  // Send request
  Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
  if (client.connected()) {
    Serial.println("Connected!");
    client.println("PUT /v2/feeds/" + String(feedID) + ".json HTTP/1.0");
    client.println("Host: http://www.api.xively.com");
    client.println("X-ApiKey: " + String(API_key));
    client.println("Content-Length: " + String(length));
    client.print("Connection: close");
    client.println();
    client.print(data);
    client.println();
    Serial.println(F("Connection failed"));
    return;
  Serial.println(F("-------------------------------------"));
  while (client.connected()) {
    while (client.available()) {
      char c = client.read();
      Serial.print(c);
  client.close();
 Serial.println(F("\n\nDisconnecting"));
 cc3000.disconnect();
  // Wait 10 seconds until next update
  delay(10000);
Your Host string seems to be doubtful.
Why not change it like the following?
  //Serial.println("Host: http://www.api.xively.com");
  Serial.println("Host: api.xively.com");
Hi tasasaki, thank you for that. I knew that mistake was there but i forgot to delete it....thanks for pointing it out.
Now I am at another error:
Here is where my serial monitor leaves off
Connect to 64.94.18.120:80
Connected!
So it seems like i connected successfully. However, I get no readings through xively, my feed page does not show anything for my sensor, and I am kind of unsure as to how to call the local libraries for the light sensor to get lux measurements. Do you have any help/suggestions?
Btw, the only instance of light measurement is with the call event.light, located in the loop function. I assign this call to a variable and then send that variable through the data stream. I am not sure if that is even correct, but it does compile and run. However as mentioned, i still see nothing on xively.
I am having the same issue. Did you ever get this worked out?
