Hi I can run this code without any problem on Arduino UNO. My output is like : 0.05 0.10 1.01
But when I run this code on ESP32, my output is : 255.89 255.81 0.99 and I don't see any minus value. What is the problem? I think esp32's minus values might be wrong.
#include <Wire.h> // Wire library - used for I2C communication
int ADXL345 = 0x53; // The ADXL345 sensor I2C address
float X_out, Y_out, Z_out; // Outputs
float X, Y, Z ;
Serial.begin(115200); // Initiate serial communication for printing the results on the Serial monitor
Wire.begin(); // Initiate the Wire library
// Set ADXL345 in measuring mode
Wire.beginTransmission(ADXL345); // Start communicating with the device
Wire.write(0x31);
Wire.write(0x0B);
Wire.endTransmission();
Wire.write(0x20); // Z-axis offset register
Wire.write(-7);
Wire.write(0x2D); // Access/ talk to POWER_CTL Register - 0x2D
// Enable measurement
Wire.write(0x08); // (8dec -> 0000 1000 binary) Bit D3 High for measuring enable
Wire.write(0x2C);
Wire.write(0x09); //For low power 000x x pin set to 1 /1001 determine Hz
delay(10);
unsigned long Time = millis();
// === Read acceleromter data === //
Wire.write(0x32); // Start with register 0x32 (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(ADXL345, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
X_out = ( Wire.read() | Wire.read() << 8); // X-axis value
X = X_out /256; //For a range of +-2g, we need to divide the raw values by 256, according to the datasheet
Y_out = ( Wire.read() | Wire.read() << 8); // Y-axis value
Y = Y_out /256;
Z_out = ( Wire.read() | Wire.read() << 8); // Z-axis value
Z = Z_out /256;
delay(20);
Serial.print(X);
Serial.print(" ");
Serial.print(Y);
Serial.print(" ");
Serial.print(Z);
Serial.println(" ");
