Arduino ADXL_345
Hello Everyone,
I have interfaced Esp8266 with ADXL345 using SPI interface and I am able to interface and read the data properly.
My doubt is Actually in the code I have configured ADXL345 register to +-16g and Full resolution (13 bit) but I am receiving the data only around 8 to 9 bit signed integer data. This code is not able to achieve till 13 bit of data.
Below is the code given with this query.
//https://forum.allaboutcircuits.com/threads/adxl345-arduino-uno-data_ready-interrupt.107207/   code link
#include <SPI.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
//ADXL345
#define INTERVAL 10 //10
#define SCLpin   14 //D5//GPIO 14 Serial clock pin
#define SDOpin   12 //D6//GPIO 12 MISO pin
#define SDApin   13 //D7//GPIO 13 MOSI pin
#define SSpin     5 //D1 //15 //D8//GPIO 15 CHip Select D8
//Nodemcu pin 3.3 -----> pin VCC ADXL345
//Nodemcu pin GND -----> pin GND ADXL345
char BW_RATE = 0x2C;   // Data Rate and power mode control
char POWER_CTL=0x2D;   // Power Control Register
char DATA_FORMAT=0x31; // Data Format Register
char DATAX0=0x32;
char DATAX1=0x33;
char DATAY0=0x34;
char DATAY1=0x35;
char DATAZ0=0x36;
char DATAZ1=0x37;
int X_Data, Y_Data, Z_Data;
char str[10];
long lastMsg=0;
byte TO_READ = 6;
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi()
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
void reconnect()
  while (!client.connected())
    Serial.print("Attempting MQTT connection...");
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    if (client.connect(clientId.c_str()))
      Serial.println("connected");
      client.publish("outTopic", "My First MQTT Code");
      client.subscribe("Welcome ESP8266");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      delay(5000);
  SPI.begin();
  SPI.beginTransaction(SPISettings(5000000,MSBFIRST,SPI_MODE3));//max 40 MHz
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  pinMode(SSpin , OUTPUT);
  digitalWrite(SSpin , HIGH);
  writeRegister(POWER_CTL, 0x00);// Configured in Stand By Mode
  writeRegister(POWER_CTL, 0x08); // Configured in Measurement Mode
  writeRegister(DATA_FORMAT, 0x0B); // ±16g 13bit, 4mg/LSB.
  writeRegister(BW_RATE, 0x0F); // Baud Rate Register configuration. 3200 Hz
  if (!client.connected())
    reconnect();
  long now = millis();
  if (now - lastMsg > INTERVAL)
    lastMsg = now;
    read_345();
    client.publish("ADXL_345",str);
   client.loop();
void read_345()
// DATAX0
  readRegister(DATAX0, TO_READ, str);
  X_Data= ((int)str[1] << 8)  | (int)str[0];
  Y_Data= ((int)str[3] << 8)  | (int)str[2];
  Z_Data= ((int)str[5] << 8)  | (int)str[4];
  sprintf(str,"%d %d %d",X_Data,Y_Data,Z_Data);
  Serial.println(str);
void writeRegister(char registerAddress, char value)
    digitalWrite(SSpin , LOW);
    SPI.transfer(registerAddress);
    SPI.transfer(value);
    SPI.endTransaction();
void readRegister(char registerAddress, int numBytes, char * str)
    char address = (0x80 | registerAddress);
    if (numBytes > 1)address = address | 0x40;
    SPI.transfer(address);
       for (int i = 0; i < numBytes; i++)
            str[i] = SPI.transfer(0x00);
How do you know? Are the lowest 4 bits always 0?
Thank you for your replyNo I have not checked it bit wise, Only with respect to data which I am receiving from the accelerometer on that basis I have asked this question?,
I will try to check it bitwise also.
Thanks
Anurag
The show us that data and tell us also what you expected.
I am new to the field of IoT. currently working on developing air mouse project using adxl345 and nodemcu amica board. I am using your code with changes I am not publishing on the net. But I am getting the output as
0 0 0
0 0 0
what is the problem. Please help me it is urgent.
#include <SPI.h>
//ADXL345
char DATAX0=0x32;
char DATAX1=0x33;
char DATAY0=0x34;
char DATAY1=0x35;
char DATAZ0=0x36;
char DATAZ1=0x37;
char str[10];
long lastMsg=0;
byte TO_READ = 6;
SPI.begin();
lastMsg = now;
read_345();
void read_345()
// DATAX0
str = SPI.transfer(0x00);
  • digitalWrite(SSpin , HIGH);*
  • SPI.endTransaction();*
