Arduino alphanumeric keypad using 4x4 keypad
Hello there,
This is a little program to take multiple input through single key from keypad. It used keypad library for arduino. The purpose of this program is to assign any numbers of Characters and stings to particular button on keypad and cycle through them one by one. it works on following 3 scenarios
  • assign multiple characters to single button and cycle through them one by one by pressing same button in some time interval.
  • assign multiple strings to single button and cycle through them one by one by pressing same button in some time interval. Note that this strings can be made of single characters to multiple characters.
  • assign long press i.e. hold button functionality to any of the above case
 * Author: Bhavesh Jadav
 * File name: keypad.ino
 * keys numbering are as follows
 *      0    1   2   3
 *      4    5   6   7
 *      8    9   10  11
 *      12   13  14  15
 * this arduino code is used to assign multiple characters or strings to single button in keypad matrix.
 * there are 3 different scenarios
 * 1) assign multiple characters to single button(which I referred to as key in this program) and cycle through them one by one by pressing same button in some time interval.
 * 2) assign multiple strings to single button(which I referred to as cmd in this program) and cycle through them one by one by pressing same button in some time interval.
 *    note that this strings can be made of single characters to multiple characters.
 * 3) assign long press i.e. hold button functionality to any of the above case
#include <Keypad.h>
#include <String.h>
//change following according to the keypad
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {19, 18, 17, 16}; //connect to the column pinouts of the keypad
//assign number to the each key as shwon in below. since I am using 4x4 keypad hence numbers are from 0 to 15.
//MAKE SURE NUMBERING STARTS FROM 0 AND THERE IS NO NUMBERS ARE MISSING BETWEEN TWO NUMBERS!
char keys[ROWS][COLS] = {
    { 0,1,2,3 },
    { 4,5,6,7 },
    { 8,9,10,11 },
    { 12,13,14,15 }
 * Following array is used to assign characters and strings to the keys
 * 1) If you want to assign character to the keys then assign characters without space for e.g. '2abcABC'
 * 2) If you want to assign strings to keys then assign strings with '-' at the end for e.g. 'caps-small-no'
 * 3) If you want to assign both character and string then you can do it like 'A-a-hello-*-ok'. by adding '-' between characters and strings.
char* keyStringArray[20] = {
  "1.*#", "2abcABC", "3defDEF", "caps-small-no-",
  "4ghiGHI", "5jklJKL", "6mnoMNO", "up-",
  "7pqrsPQRS", "8tuvTUV", "9wxyzWXYZ", "down-",
  "left-", "0 ", "right-", "tare-"
 * if you want to assign long press button functionality to any button then assign function using following array.
 * make sure to assign to appropriate button.
char* longPressKeyStringArray[20] = {
  "cancel", "", "menu", "zero"
//999 to indicate end of array
int alphaKeys[] = {1, 2, 4, 5, 6, 8, 9, 10, 999};  //add numbers of keys which are going to represent alphabet.
int singlePressKeyButtons[] = {0, 1, 2, 4, 5, 6, 8, 9, 10, 13, 999};  //add numbers of keys which are going to cycle through characters
int singlePressCmdButtons[] = {3, 7, 11, 12, 14, 15, 999}; //add numbers of keys which are going to cycle through strings
int longPressCmdButtons[] = {12, 14, 15, 999};  //add numbers of characters which are going to have long press button functionality
static byte kpadState;  //to store key state i.e. PRESSED, HOLD or RELEASED
char textMode[10] = "no";  //initial text mode, no = numbers, caps = capital alphabet, small = small alphabet
byte keyState = 0;  //0 = released, 1 = hold
int textModeKey = 3; //assign textmode key number to this variable.
char valueToSend[50] = {}; //it will store final value to send to the serial monitor.
unsigned long TimeInMillis;
//initialize the keypad
Keypad key_pad(makeKeymap(keys), rowPins, colPins, sizeof(rowPins), sizeof(colPins));
//follwoing array will used to store the number of times the key is pressed which will help to cycle through characters or strings.
int keyCounterArray[16] = {0};
  key_pad.begin(makeKeymap(keys));
  key_pad.addEventListener(keypadEvent);
  //key_pad.setDebounceTime(100);
  key_pad.setHoldTime(2000);
  TimeInMillis = millis();
  int val = key_pad.getKey();
//minimum time in milliseconds required between two key press to cycle through values
int TimeDiffBtwnKeyPress = 1500;
//following function is used to cycle through characters
//startIndex and endIndex are used to cycle through particular part of character array. this is important because
//in 'caps' text mode we only want to cycle through capital letters, in 'small' text mode we only want to cycle through small letters etc.
void getKeyFromKeyPress(int keyVal, int beginIndex, int endIndex){
  char subString[50] = {};
  strncpy(subString, keyStringArray[keyVal] + beginIndex, endIndex - beginIndex);
  if((millis() - TimeInMillis) < TimeDiffBtwnKeyPress && strstr(subString, valueToSend) != NULL)
      keyCounterArray[keyVal]++;
  else{
    keyCounterArray[keyVal] = 0;
  if(keyCounterArray[keyVal] == strlen(subString))
  valueToSend[0] = subString[keyCounterArray[keyVal]];
  valueToSend[1] = '\0';
  Serial.println(valueToSend);
//following function is used to cycle through strings
void getCommandFromKeyPress(int keyVal){
  int counterLimit = 0;
  int i = 0, j = 0, k = 0;
  while(keyStringArray[keyVal][i] != '\0'){
    if(keyStringArray[keyVal][i] == '-')
      counterLimit++;
    i++;
  if((millis() - TimeInMillis) < TimeDiffBtwnKeyPress && strstr(keyStringArray[keyVal], valueToSend) != NULL && valueToSend != "")
  else{
  if(keyCounterArray[keyVal] == counterLimit)
  char cmds[10][10] = {0};
  while(keyStringArray[keyVal][k] != '\0'){
    while(keyStringArray[keyVal][k] != '-'){
      cmds[i][j] = keyStringArray[keyVal][k];
      k++; j++;
    i++; k++; j = 0;
  strcpy(valueToSend, cmds[keyCounterArray[keyVal]]);
//following function is used for long press functionality
void getCommandFormLongKeyPress(int keyVal){
  if(longPressKeyStringArray[keyVal] != ""){
    strcpy(valueToSend, longPressKeyStringArray[keyVal]);
void keypadEvent(KeypadEvent key){
  kpadState = key_pad.getState();
  int keyVal = key;
  switch(kpadState){
    case PRESSED:
    case HOLD:
      if(isValueInArray(keyVal, longPressCmdButtons)){
        keyState = 1;
        getCommandFormLongKeyPress(keyVal);
    case RELEASED:
      if(keyState == 1)
        keyState = 0;
      else if(isValueInArray(keyVal, singlePressCmdButtons))
        getCommandFromKeyPress(keyVal);
      //following part of code will use startIndex and endIndex of particular part of character array to cycle through on that much part.
      else if(isValueInArray(keyVal, alphaKeys) && strcmp(textMode, "caps") == 0)
        getKeyFromKeyPress(keyVal, (strlen(keyStringArray[keyVal])/2) + 1, strlen(keyStringArray[keyVal]));
      else if(isValueInArray(keyVal, alphaKeys) && strcmp(textMode, "small") == 0)
        getKeyFromKeyPress(keyVal, 1, strlen(keyStringArray[keyVal])/2 + 1);
      else if(isValueInArray(keyVal, singlePressKeyButtons) && strcmp(textMode, "no") == 0)
        getKeyFromKeyPress(keyVal, 0, 1);
      else if(isValueInArray(keyVal, singlePressKeyButtons))
        getKeyFromKeyPress(keyVal, 0, strlen(keyStringArray[keyVal]));
      if(keyVal == textModeKey)
        strcpy(textMode, valueToSend);
bool isValueInArray(int val, int *arr){
    int i = 0;
    while (arr[i] != 999) {
        if (arr[i] == val)
            return true;
        i++;
    return false;
Any feedback is appreciated.
How can I save the input in a variable
