Hallo,
Onlangs heb ik mezelf ambilight gemaakt voor mijn 41" tv. Maar op sommige films heb je vanboven en vanonder zo'n zwarte balk. Waardoor alle LEDs vanboven en vanonder zwart blijven.
Is hier een oplossing voor om dit probleem op te lossen. Ik heb al op google zitten rond zoeken maar daar vind ik niks van code.
De code die ik op mijn Arduino micro gebruik is:
// Slightly modified Adalight protocol implementation that uses FastLED
// library (http://fastled.io) for driving WS2811/WS2812 led stripe
// Was tested only with Prismatik software from Lightpack project
#include "FastLED.h"
#define NUM_LEDS 166 // Max LED count
#define LED_PIN 6 // arduino output pin
#define GROUND_PIN 10
#define BRIGHTNESS 255 // maximum brightness
#define SPEED 115200 // virtual serial port speed, must be the same in boblight_config
CRGB leds[NUM_LEDS];
uint8_t * ledsRaw = (uint8_t *)leds;
// A 'magic word' (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch). You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided -- fewer false positives. The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55). LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
static const uint8_t magic[] = {
'A','d','a'};
#define MAGICSIZE sizeof(magic)
#define HEADERSIZE (MAGICSIZE + 3)
#define MODE_HEADER 0
#define MODE_DATA 2
// If no serial data is received for a while, the LEDs are shut off
// automatically. This avoids the annoying "stuck pixel" look when
// quitting LED display programs on the host computer.
static const unsigned long serialTimeout = 150000; // 150 seconds
pinMode(GROUND_PIN, OUTPUT);
digitalWrite(GROUND_PIN, LOW);
FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
// Dirty trick: the circular buffer for serial data is 256 bytes,
// and the "in" and "out" indices are unsigned 8-bit types -- this
// much simplifies the cases where in/out need to "wrap around" the
// beginning/end of the buffer. Otherwise there'd be a ton of bit-
// masking and/or conditional code every time one of these indices
// needs to change, slowing things down tremendously.
uint8_t
buffer[256],
indexIn = 0,
indexOut = 0,
mode = MODE_HEADER,
hi, lo, chk, i, spiFlag;
int16_t
bytesBuffered = 0,
hold = 0,
c;
int32_t
bytesRemaining;
unsigned long
startTime,
lastByteTime,
lastAckTime,
t;
int32_t outPos = 0;
Serial.begin(SPEED); // Teensy/32u4 disregards baud rate; is OK!
Serial.print("Ada\n"); // Send ACK string to host
startTime = micros();
lastByteTime = lastAckTime = millis();
// loop() is avoided as even that small bit of function overhead
// has a measurable impact on this code's overall throughput.
for(;;) {
// Implementation is a simple finite-state machine.
// Regardless of mode, check for serial input each time:
t = millis();
if((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) {
buffer[indexIn++] = c;
bytesBuffered++;
lastByteTime = lastAckTime = t; // Reset timeout counters
else {
// No data received. If this persists, send an ACK packet
// to host once every second to alert it to our presence.
if((t - lastAckTime) > 1000) {
lastAckTime = t; // Reset counter
// If no data received for an extended time, turn off all LEDs.
if((t - lastByteTime) > serialTimeout) {
memset(leds, 0, NUM_LEDS * sizeof(struct CRGB)); //filling Led array by zeroes
FastLED.show();
lastByteTime = t; // Reset counter
switch(mode) {
case MODE_HEADER:
// In header-seeking mode. Is there enough data to check?
if(bytesBuffered >= HEADERSIZE) {
// Indeed. Check for a 'magic word' match.
for(i=0; (i<MAGICSIZE) && (buffer[indexOut++] == magic[i++]););
if(i == MAGICSIZE) {
// Magic word matches. Now how about the checksum?
hi = buffer[indexOut++];
lo = buffer[indexOut++];
chk = buffer[indexOut++];
if(chk == (hi ^ lo ^ 0x55)) {
// Checksum looks valid. Get 16-bit LED count, add 1
// (# LEDs is always > 0) and multiply by 3 for R,G,B.
bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
bytesBuffered -= 3;
outPos = 0;
mode = MODE_DATA; // Proceed to latch wait mode
else {
// Checksum didn't match; search resumes after magic word.
indexOut -= 3; // Rewind
} // else no header match. Resume at first mismatched byte.
bytesBuffered -= i;
case MODE_DATA:
if(bytesRemaining > 0) {
if(bytesBuffered > 0) {
if (outPos < sizeof(leds))
ledsRaw[outPos++] = buffer[indexOut++]; // Issue next byte
bytesBuffered--;
bytesRemaining--;
// If serial buffer is threatening to underrun, start
// introducing progressively longer pauses to allow more
// data to arrive (up to a point).
else {
// End of data -- issue latch:
mode = MODE_HEADER; // Begin next header search
FastLED.show();
} // end switch
} // end for(;;)
// Not used. See note in setup() function.
De code die ik in processing gebruik, is de adalight.pde van het adalight project: Download & Install | Adalight Project Pack | Adafruit Learning System
Iemand die kan helpen ?
Alvast bedankt,
Svenq
