Arduino analog clock help
So I decided to try and build a analog clock using an arduino nano and 3 1ma meters and DS3231 RTC. I have had pretty good success with arduinos but this project has stumped me.I have everything built and my hours and minutes are showing up correctly on my meters but my seconds do nothing.It goes to a certain value on startup sits there and goes low after several seconds and never increases with time.Minutes and hours work just fine.Also this same project is out there on the internet and it works for them using the same coding,components and wiring as they do.When I use serial monitor it is showing the right time and seconds increasing.I'm new to the forums so if this belongs somewhere else let me know.I'm using 5k resistors for the + side of the meter.I went through the coding as best I could and couldn't find anything wrong.Maybe someone with more knowledge could help me out.Thanks.
Analog Panel Meter - Clock ONLY Mode
Instructables Link: http://www.instructables.com/id/Analog-VU-meter-and-Clock-Arduino-Powered/
Credits:
bildr - DS1307 RTC code http://bildr.org/2011/03/ds1307-arduino/
Wiring goes as follows:
  • USB red wire (5v) to VCC
  • USB black wire to GND
  • Buttons - Left/Down to Digital 2 (follow arduino tutorial: http://arduino.cc/en/uploads/Tutorial/button.png )
  • Right/Up to Digital 3
  • DS1307 RTC - SDA to Analog 4
  • SCL to Analog 5
  • Left Analog Meter to Digital 5 (PWM)
  • Right Analog Meter to Digital 6 (PWM)
    -Seconds Analog meter to Digital 9(PWM)_____________________
Note:
Because all meters are slightly different, the PWM values
need to be adjusted based on your design. Feel free to use
my code, but you will have to change some values because
it is set to work specifically with my meters.
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
int downButton = 2; // down push button to adjust time (pin 2)
int upButton = 3; // up push button to adjust time (pin 3)
int hours = 0;
int minutes = 0;
int seconds = 0;
int lastMinute = 0;
int lastSecond = 0;
int leftMeter = 5; // left meter (hours) is attached to pin 5
int rightMeter = 6; // right meter (min) is attached to pin 6
int secMeter=9; //seconds meter (sec)is attached to pin 9
void setup(){
Wire.begin();
//Serial.begin(9600); //view time in serial monitor
pinMode(leftMeter, OUTPUT); // Initialize Outputs & Inputs
pinMode(rightMeter, OUTPUT);
pinMode(secMeter, OUTPUT);
digitalWrite(leftMeter, HIGH); // Test meters on startup
digitalWrite(rightMeter, HIGH);
digitalWrite(secMeter, HIGH);
digitalWrite(13, HIGH);
delay (1000);
digitalWrite(leftMeter, LOW);
digitalWrite(rightMeter, LOW);
digitalWrite(secMeter, LOW);
digitalWrite(13, LOW);
void loop(){
printDate();
delay(75);
// Changing the time with buttons
if (digitalRead(downButton) == HIGH){
byte second = seconds; // Don't get confused: second is not the same as seconds
byte minute = minutes; // Don't get confused: minute is not the same as minutes
byte hour = hours; // Don't get confused: hour is not the same as hours
if (minutes > 0){
--minute;
}else{
minute = 59;
if (hours > 0){
-- hour;
}else{
hour = 23;
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(zero); //start
Wire.endTransmission();
if (digitalRead(upButton) == HIGH){
byte second = 0;
if (minutes < 59){
++minute;
}else{
minute = 0;
if (hours < 23){
++ hour;
}else{
hour = 0;
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
void printDate(){
// Reset the register pointer
Wire.write(zero);
Wire.requestFrom(0x68, 7);
seconds = bcdToDec(Wire.read());
minutes = bcdToDec(Wire.read());
hours = bcdToDec(Wire.read() & 0b111111); //24 hour time
//print the date
//Serial.print(hours); // Un-comment to view time in serial monitor
//Serial.print(":"); //
// Serial.println(minutes);Serial.print(":"); // Don't forget to un-comment 'Serial.begin' in 'void setup' above
// Serial.println(seconds);
// Specific meter levels for each hour
// You will likly have to adjust these values.
// Play around with the values until you get what you want.
if (lastMinute != minutes){
if (hours == 1 || hours == 13){
analogWrite(leftMeter, 0); // adjust left (hour) meter level
if (hours == 2 || hours == 14){
analogWrite(leftMeter, 29); // adjust left (hour) meter level
if (hours == 3 || hours == 15){
analogWrite(leftMeter, 52); // adjust left (hour) meter level
if (hours == 4 || hours == 16){
analogWrite(leftMeter, 75); // adjust left (hour) meter level
if (hours == 5 || hours == 17){
analogWrite(leftMeter, 98); // adjust left (hour) meter level
if (hours == 6 || hours == 18){
analogWrite(leftMeter, 130); // adjust left (hour) meter level
if (hours == 7 || hours == 19){
analogWrite(leftMeter, 152); // adjust left (hour) meter level
if (hours == 8 || hours == 20){
analogWrite(leftMeter, 172); // adjust left (hour) meter level
if (hours == 9 || hours == 21){
analogWrite(leftMeter, 192); // adjust left (hour) meter level
if (hours == 10 || hours == 22){
analogWrite(leftMeter, 213); // adjust left (hour) meter level
if (hours == 11 || hours == 23){
analogWrite(leftMeter, 234); // adjust left (hour) meter level
if (hours == 0 || hours == 12){
analogWrite(leftMeter, 255); // adjust left (hour) meter level
if (minutes * 4.75 < 255){ // increase PWM value by 4.75 each minute
analogWrite(rightMeter, minutes * 4.75); // I had to use 4.75 on my meter to get 30 minutes to point exactly straight up
}else{ // perfect would be 4.25 because 4.25 * 60 = 255
analogWrite(rightMeter, 255);
lastMinute = minutes;
if (seconds * 4.25 < 255){
analogWrite(secMeter, seconds*4.25);
}else{
analogWrite(secMeter, 255);
lastSecond = seconds;
anal_clock.ino (6.18 KB)
Hi and welcome to the forum. Please read the forum guide which will tell you how to post code correctly on the forum, as well as other useful advice such as posting a schematic. Then modify your post above and correct it. Thanks!
Dsk11:
First of all make sure the hardware your code is written for matches the hardware you use.
Secondly, why aren't you using one of the many ready-made libraries to read whichever RTC you actually have? That, combined with the TimeLib library, makes working with time so easy...
Dsk11:
I have everything built and my hours and minutes are showing up correctly on my meters but my seconds do nothing. It goes to a certain value on startup sits there and goes low after several seconds and never increases with time.
The code looks correct (assuming you are running on an Arduino where Pin 9 is a PWM pin). If you connect the Hours meter to Pin 9, does it work for Seconds? If it does, the problem is likely in the Seconds meter or its wiring.
