When I run it and have nothing plugged into A1 the reading is around 340 and only varies slightly. When I plug in a wire and have the wire laying there not connected to anything the readings jump from 200s to 500s. When I grab the wire insulation the readings go even crazier.
That is normal. When you have nothing electrically wired to a analog pin it is said to be in a floating input pin condition and will be subject to reading random electrical noise. Wire the analog input pin to ground or +5vdc and see how steady the readings become. What and how you wire things to the analog input pin is important, if you expect them to work correctly.
What is the ohm value of the pot you are trying to use and how have you wired it up? 10k or less is the pot value you should be looking for.
Okay. That makes sense. I guess I should move this out of troubleshooting then.
I need to start a new thread about why this still happens when I solder that pin to the pot on a xbox 360 controller. The readings look exactly the same. Do I need to take the 3.3v from the controller to the AREF?
nikescar:
Did you also wire a ground wire from the arduino to the xbox? That would be required.
