I require 3 analog input pins (A0, A1 and A2) for reading analog sensor values and the remaining 3 (A3, A4, A5) as digital outputs.
The digital outputs are given to an Analog MUX. The analogRead() will be called frequently, just after setting the digital outputs.
Will the switching of digital pins affect the analog readings taken?
If yes, then what changes should I make, other than adding a delay before calling analogRead()?
