Arduino analogread to mysql
Hi guys. I want to send arduino analog pin data to mysql server, but it gives the following error:
Error: 163 = You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '')')')' at line 1.
can someone help me ? here the project sketch:
#include <Ethernet.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#define ANALOG_PIN_1 1
int val;
byte mac_addr[] = { 0xFE, 0xBD, 0xCD, 0xCB, 0xA8, 0xAA };
IPAddress server_addr(10, 5, 51, 13); // IP of the MySQL *server* here
char user[] = "arduino";              // MySQL user login username
char password[] = "12345678";        // MySQL user login password
// Sample query
char INSERT_SQL[] = "INSERT INTO hello.test (message) VALUES ('%s')";
EthernetClient client;
MySQL_Connection conn((Client *)&client);
  while (!Serial); // wait for serial port to connect
  Ethernet.begin(mac_addr);
  Serial.println("Connecting...");
  if (conn.connect(server_addr, 3306, user, password)) {
    Serial.println("Connection failed.");
  val = analogRead(ANALOG_PIN_1);
  char query[80];
  sprintf(query, INSERT_SQL, val);
  Serial.println("Recording data.");
  // Initiate the query class instance
  MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
  // Execute the query
  cur_mem->execute(INSERT_SQL);
  // Note: since there are no results, we do not need to read any data
  // Deleting the cursor also frees up memory used
  delete cur_mem;
and sql script:
  CREATE DATABASE hello;
  CREATE TABLE hello.test (
    num integer primary key auto_increment,
    message char(40),
    recorded timestamp
When you use this string for your sprint() function, %s specifies you are passing in a string, but
is passing in an int
use
char INSERT_SQL[] = "INSERT INTO hello.test (message) VALUES ('%d')";
you could also help yourself with a debug message
Serial.print("SQL: " ); Serial.println(query);
thanks for reply. but I get %d value in mysql table
Screenshot 2022-01-05 181930
Did you take the other advice and print the query?
yes with this example https://github.com/ChuckBell/MySQL_Connector_Arduino/blob/master/examples/basic_insert/basic_insert.ino I can read the Hello, Arduino! in mysql table.
The idea is to print the result of the sprintf to serial so you can see what's wrong with it.
OK I do it and it's always printing number 48
Screenshot 2022-01-05 184114
Nope. Print the query variable.
showing this: INSERT INTO hello.test (message) VALUES ('%s')
Don't forget to look at the Web site's logs, they are a source for some of the reasons of failure.
I know with MySQL dB, I had to see which IP address were being refused connections to the dB and open those address up to being allowed to connect to the dB.
I found using HTTP POST to work quite well, ESP32 HTTP GET and HTTP POST with Arduino IDE | Random Nerd Tutorials.
Time to post your latest code I think.
Well, the problem is, I do not know what to do
Then you didn't edit your INSERT_SQL variable.
With this code:
  int val = 100;
  char query[80];
I get:
Recording data.
SQL: INSERT INTO hello.test (message) VALUES ('100')
You need to be using query here, not INSERT_SQL
WoW thanks. I replaced the query with INSERT_SQL now working like a charm. thanks you saved my day. :heart_eyes:
